Na-na-na-an, I can't hear you. Repeat after me, "it was hot, your breather is clogged, you just sent a little oil past the seal"
The wheel doesn't feel loose, but I do have a full rebuild kit that has been sitting in the parts drawer for seven years.
The axle shaft being bolted to the hub flange then going all the way into the diff can make the wheel feel like it doesn't have play even when the bearings are a bit loose.
Just pop the cone washers off and pull the axle shaft then check preload. You may not need seals or a bearing rebuild at all.
