Incredibly old post. looking at replacing front speed sensor. looking for info on repacking hubs. Found this thread
can someone tell me if I am looking at doing ALL of this, or direct me to the section I should expect?
Thanks
Below are the part numbers for my 2008. Those are prices from PartSouqpart number?
Was it 1 ohm, or was it showing a 1 because it was an open circuit? I'm trying to find out what is normal for the ohms.So my VSC, ABS, and TRAC lights went off. Checked all the resistance for the sensors and got 1 ohm for the front and 1.3 for the rear so I think the sensors are fine. Before taking to the mechanic I’d like to know what else should I checked so I have a better understanding of the problem so don’t get ripped off. Do you have any recommendations? 2001 LC w/ 160K miles. Thanks for all the help!
Mine are reading 2.5k ohms on the front. I just replaced the front ones and that fixed my problem for a day or two, and now my VSC, ABS, and TRAC lights are on again (but not the brake light like last time).
You should be able to pull it out from the rear, mines crumbled apart tho. Ebay sensor still working good for meso it is not necessary to remove the calipers/rotors from the hub in order to replace the front abs sensor? just gotta use the picks and dremel tool?
I have the same code, just instead of front mine is my rear passenger side wheel speed sensor. I think it is triggering the C1223 C1241 C1340 did fixing the wheel speed sensor clear these other codes. I have read this can trigger them since they are all sort of in the same family. Thanks!Another thread revival: I had the ABS, VSC Trac, and VSC Off lights come on last weekend while driving through the mountains (scary having ATRAC engage at speed). Tried to pull the codes with a cheap bluetooth OBDII scanner but only had P0171 returned (hopefully O2 sensor, but that's another story). I managed to get someone to pull the ABS codes for me, which returned way more codes than I was expecting:
So I'm wondering if replacing both front wheel speed sensors will fix these codes or if it will be something slightly more involved. I'm going to try to remove the sensors and clean them first, before purchasing and replacing both with new sensors. Any thoughts on what might have caused these codes to appear under normal driving conditions?
Also, are the wheel speed sensors interchangeable between 98-02 and 03-07?
