so where is the video for the FT anybody ?if anyone is curious on the dial gauge that does fit the factory timing device this one works.
So the removal of ACSD effects the timing spec and compensation is needed ?so denco diesel also lists this pdf for timing specs. located here https://www.dencodiesel.com/Timing-a-VE-Style-Fuel-Pump.pdf they list a specific specification for 1hd-t pump with the acsd and 8mm spacer.
"Toyota 1HDTFactory Turbo 1.29-1.35mm ACSD with 8mm spacer@ TDC "
what are the specifications if you have removed this acsd device?
I have also found this denso service builten for our injection pumps I hope this info I share comes in handy too.
http://dieselmastera.ru/_fr/5/VE_ETVZ9703-PRE.pdf
Ooooow, shiny!!
Hi, guys, I'm still confused about what the timing spec should be with the ACSD Removed.Bumping this thread!!! Does anyone know the Specifications if you removed the ACSD on a 1HD-T? or Verify my Findings please!!!
This is taken from the FSM
I am assuming the Plunger stroke for early 1991 1HD-T 1.18-1.24 mm is correct as it does not list a 1HD-T with ACSD in the FSM?
^^ The above specs was taken from the latest fsm I have 1998 - RM617EView attachment 3351816
in the older 1990 - RM172E FSM the specs are 1.29-1.35 mm but I think this one is ACSD only same specs from Denco Diesel website too.
I’m sure someone knows. There are lots of 1HD-T with the acsd removed my self included been running with out retiming and I haven’t noticed any difference. I just want to set it up correctly.I am curious as well, I have the old 1990 FSM for the 1HZ and 1 HDT.
The only thing the ACSD does is increase timing during start up when engine coolant is cold. Once engine is up to temp the hot coolant moves the timing advanced piston back to normal position. If you aren't having any starting issues then it's fine, there's nothing "incorrect" about not timing it after removing ACSD. Some pumps are old and worn and suffer cold start issues once ACSD removed so those bump the static timing up a bit to help.I’m sure someone knows. There are lots of 1HD-T with the acsd removed my self included been running with out retiming and I haven’t noticed any difference. I just want to set it up correctly.
So if I were to check it anywise should I aim for 0.85-0.91mm???The only thing the ACSD does is increase timing during start up when engine coolant is cold. Once engine is up to temp the hot coolant moves the timing advanced piston back to normal position. If you aren't having any starting issues then it's fine, there's nothing "incorrect" about not timing it after removing ACSD. Some pumps are old and worn and suffer cold start issues once ACSD removed so those bump the static timing up a bit to help.
That's 1HZ specs, don't you have a DT?So if I were to check it anywise should I aim for 0.85-0.91mm???
Yes I have 1HD-T Ok then 1.18 - 1.24 mmThat's 1HZ specs, don't you have a DT?
There's two specs because they changed the design of the DT piston combustion bowls.Yes I have 1HD-T Ok then 1.18 - 1.24 mm
Or
1.29 - 1.35 mm for 1HD-T not sure why there’s 2 specs.
ok thanks, I think ill go with 1.29 - 1.35 mm for 1HD-T as I have an early 1991 1hd-tThere's two specs because they changed the design of the DT piston combustion bowls.
