How to strain rusty gas
Made the mistake of putting 10 gallons of good gas in a rusty tank, now the filter keeps getting clogged.
Got a new tank comin,. Whats the best way to try and save that gas?
Pour in cans and let sit, strain thru cheesecloth, etc?
I dont know if the drain plug will even come out to begin with.
Not looking forward to it but dont want to waste 35.00 in good gas!
I would suggest letting it sit for a while, and then let it strain through some paper coffee filters. But realistically, I would try it with a few cups, and if it doesnt work, just toss the fuel, how much time are you willing to spend to save a little gas?
yea I would do what he said, it will take a little while. try to use a metal strainer or something to support the cloth. definitely pour it in something that you can inspect it afterwards, and make sure the area is ventilated. I had this same issue with my gas tank, pulling over every 100 miles to clean my fuel filter on the side of the road and putting it back on....
I have to pull over every 3 blocks!
the rust is so fine that it clogs it up asap.
I guess I will pour into jerry cans and let sit for a month- then slowly strain into another can and toss the bottom out?
Pour the gas into a plastic container or bucket through some cheese cloth and then take a donut magnet and tie on a string and suspend in the gas to attract any metal/rust that made it through your strainer.
Or, admit your $35-$40 mistake and dump it all and start over with a thoroughly cleaned and sealed tank.
Large magnet surrounded by cheese cloth .Place it in 5 gallon bucket and drain in gas, let sit awhile drain slowly into another bucket with more filter material. This saves most of your gas. Mike
Or do your best and then put it in your lawn mower so when it messes up your day you're still close to the fridge. :beer:
Let it sit in whatever container you choose for an hour or so. Gently poor it in to a funnel with any sort of paper filter (even a paper towel), leaving the dregs to be discarded.
No big deal, no big fuss.
Mark...
I went to Home Depot and bought two 5 gallon orange buckets. Siphoned the gas through the fill hole with a hose. Let the gas sit for a couple of hours and it was fine. All the bad stuff settled to the bottom and was very visible. I had to do this twice when I changed to a new tank on my '79. Once to get the old gas out, then the new tank ended up having a bad solder joint so drained again and silver soldered the fitting ( and added a bottom drain plug at the same time). Now I have two nice buckets with lids for radiator draining etc.
I have alot of other gas eating machines I could use the gas on.
I think I will take the best advice and not re-use it in a brand new tank.
I am going to mix it in with some 2 stroke and we got ourselves a party!
Thanks for the help.
Ted
