- Thread starter
- #101
@LandCruiserPhil
You should include an option on your site for those of us who are electrically challenged to buy the whole package (fan, brackets, and wiring for dummies)![]()
Did you miss post #93
@LandCruiserPhil
There are many ways to wire an AUX fan some more complicated than others.
With that said our goal is 100% plug and play requiring 1 banana and no electrical knowledge for an successful installation.
100% Plug and Play Wiring Kit has 2 options, power with or without key on or off to keep it simple.
No worries on leaving the fan on if you choose the key on power option.
Will be available by the end of the week.
Any questions?
You will be cool before you know itDon't worry about me fellas, for I overcame my adversity.View attachment 1500053
Looks factory![]()
I would like to buy a kit from you please.100% Plug & Play for the electrical challenged - You need no parts for a 100% operational aux fan
100% Plug & Play Kit
$210 shipped in the 48 states
$185 Cash & Carry / pick up
If you choose to use a Toyota Factory fan our wiring kit and bracket kit available deduct $90
100 Series aftermarket fan
Mounting brackets and hardware
Wiring harness labeled - If you can match numbers and letters you will be fine
Shipped in the 48 states
Pictured what you will get
Fan connection Match A-A and B-B done
Switch wiring 1-1 2-2 3-3 done
Piggy back power Plug in. Your power choice 1) Power at all times to switch 2) Key on power to switch
Ground to bolt near switch
Switch mounts in existing blank. (If you screw up the hole for your new switch factory replacement blanks are available for $5)
Kit features
True LED illuminated (blue) 25A rated switch
16ga wiring
All connection crimped solid
Piggyback fuse connection with 10A fuse
Solid #12 wire for fishing wires
Black tape for connecting fish wire to harness
Cable ties to secure wiring
This is as easy as it gets
Questions?
