So would you recommend routing the rear diff just out the gas filler cap without drilling through the filler cap cover? and not to the front engine bay/firewall where the ARB head (there are 4 ports that can be used up there) w/ filter would be attached? Any photos you may have of this install or just a few pics from under your rig with them installed and some fingers pointing to the diff lines if they are not obvious? I'm going to install these today so any help would be much appreciated!Keep the hose runs as vertical as possible. I routed the rear up along the fuel filler hose to just behind the filler cap. For the front diff, I routed it up near the air box. For the t case and trans, I used a y-connector and routed them to one breather to the top of the trans dipstick.
Has anyone tried to route the diff breathers up through the air intake and through a snorkel? That sounds crazy/stupid just writing it but...you gotta ask the question right? It seems the higher the better when we are talking about water getting into the tube top.
