- Thread starter
- #21
I sort of feel you are going about this wrong. Use the right bearing, set the pinion depth correctly, then set pinion pre-load, then set backlash and carrier pre-load. You really can't use a pinion shim that almost works. It's a pretty exact science.
I do applaud you for doing this on your own, because it means you understand the process, and have bought all the special tooling to do it correctly.
But it's a re-iterative process. Apart and back together maybe 6-10 times to get it right. No way to fake it.
I'm not sure what you mean when you say I'm going about it wrong. I believe the bearing that I was provided in the install kit is incorrect. So, I will be swapping it for a used bearing I have on hand to see if I can get the correct pattern. If that works hopefully I can pick up a new bearing locally tomorrow. If there is something I'm doing that's fundamentally wrong please point it out.
