How do you check front suspension
Kansas
I'm curious what system you guys use to check for failures in the front suspension. Recently the 94 has developed a pretty good clunk coming from the DS front. Happens when you hit bumps. I have already gone under there and tightened up the knuckle studs which were coming loose. I'm assuming I have a bad shock but I generally like to be very systematic about my checks.
Shocks are easy, bounce of the front bumper and if it bounces more than like twice, you probably need shocks. But you would then notice a lot of bounce over bumps... Have you? A clunk could be a loose shock, bad bushings, or a bent sumthin or another. I would jack it up, take off the tires and get to know your front end.
FWIW, if your knuckle studs were loose, you never know what else could be, or if your knuckles / trunnions were damaged as a result.
