How can I remove these from my top?
Tucson, Arizona
there are 2 metal pieces that I can’t figure out how they are attached- there has to be a way to remove for refinish and new gasket....help please.
Awesome advice - THANKS. I tried searching the archives but could not locate the referenced link. Very helpful.
its easier to remove the lower piece first before you remove the top.
They slide together. If you are patient, you can slide them apart without destroying them. You have to feed some oil in and tap on them gently to break the bond.
I used a piece of old wood trim piece as a wedge and rubber malett.Tapping the lower piece on one end so it slid out and separated.
You can also try gently prying with a large flathead between the 2 pieces to seperate, then slide the lower out.
The hard part is being gentle.
