How big are cat nuts?
MA
ok...my front O2 sensor launched itself while driving down the road. It didn't get very far since it was attached to the vehicle harness. It looks like the nuts rusted. I stopped at the nearest hardware store and try 8.0mm-1.0 and 8.0mm-1.25 and neither seemed to fit. I also tried some SAE nuts, I think 5/16-20 and 5/16-24 and they didn't fit either. Any ideas?
I can't recall the size and pitch but they are the same as Honda Accord exhaust manifold nuts. When I was at the local Schuck's digging through their parts bin and they didn't have enough the guy behind the counter suggested I look on their racks of common bolts, hooks, etc... Sure enough the Honda exhaust studs and nuts worked great.
The cats aound here are neutered so there are no nuts to measu.......... :whoops:
Never mind.............:flipoff2:
Oxygen sensor nuts are 8x1.25 mm.........
Thanks guys....who knows if I actually bought 8.0-1.25 at Home Depot....you can never be sure with the lack organizing...and if I did..I will assume rust was the issue for not going on...
I'm holding some right now. They are small.
Ok, I'll hijack :D
What size are the bolts/nuts between the 2 cats on a 96??
I'm replacing the gasket between them tonight and the hardware
is rusted junk
10x1.25mm
All ya gotta do is scratch 'em regular and you learn a lot.....:)
As posted 8x1.25
My left cat O2 didn't have any nuts on it either. PO used some sort of glue on the threads. At first I thought the nuts rusted off, but after more careful inspection...... ugh, glue.
The right side, I just replaced, too. Rusted and sheared when I tried to wrench them off. Vice grips to the rescue!
