hates riding in it
isnt that thing a rattle can with the 4bt?Go with the 4BTA, easier to fit and a bit lighter. I have one mated to a 700R4 tranny and 62 series split t/case, and it rolls pretty good. You have to do at least a 4" suspension lift to provide for adequate axle to oil pan clearance.
Has tons of low end torque and with the OD transmission, cruises pretty good on the highway at 65-ish with 19+ mpg if you drive it right
But, it is loud and prolly not the best for a daily driver. Thehates riding in it
If you really want to do it, though, it IS doable. There are a few guys that have swapped the 6BT (5.9L) into their 80s.
isnt that thing a rattle can with the 4bt?![]()
How much does that beast weigh versus the 3FE? The 4BTA weight about 675-720lbs depending on the configuration.
I have the OME Heavies and the truck rides very well and level, granted when I empty all the junk outta the back and get low on gas, I do get a little "stinkbug" action going on![]()
Those are base weights, the 4BT is closer to about 800-900lbs or more so heavier than a 1HZ but especially in early 80s the transmission is huge and heavy so sometimes they counter act each other depending on your trans choice, or sometimes you need to compensate for the extra weight. The vibration isn't bad at all, one of the big misnomers about 4BTs for some reason, they rattles around a little at idle but is otherwise pretty smooth. Above 45 it gives a nice little diesel purr that you can hardly hear over the vehicle than it is sort of comfortingThe big issue is the noise around town which is loud, and that you need a solid 4" of lift so you have to run 35's or larger and for a DDer it is a little large. Sometimes you love it sometimes you hate it sort of like having a sweet GTO or something like that
The torque is awesome and every rig I've seen with a 4BT wheels like it is going out of style. You also usually get 20mpg fairly easier or higher depending on your configuration. I've seen some 80s with as low as 18 or so mpg but it is nice.
I hope it helps, also there is plenty of good info at www.4btswaps.com which I started when I had my first 4BT powered 55. Cheers, Andre
