Still having the intermittent starting issue on my 94 and I was hoping for some help. Let me tell you a bit about what i have done. First I cleaned all the contacts, worked for a week or so, then I checked the starter and cleaned it and eventually ordered a Denso starter, worked for a few days or so, then I found the thread to check the neutral safety switch and on the 94 I removed the starter again to get to the connections above the starter. I took them apart and they did not look bad at all but I got some electrical parts spray and a tooth brush and cleaned them all and put some di electric grease and connected. Again worked for about 4 days until today and again the click. I also ordered the painless performance hotshot 30202 relay kit after reading about it. Roncruiser mentioned just to skip the other "fixes" and install this kit. I thought I saw somewhere that he mentioned that it has been years with no problems. I need help regarding the install. Below is a link for the install and I dont know sh#t about electrical.
http://www.painlessperformance.com/Manuals/30202.pdf
Step 5: Where do I connect the heavy gauge purple wire to the same small terminal i removed the wire from in step 3, useing the yellow ring. It only has the black connector that connects to the starter.
Step 7: Where should I splice in the small purple wire to the wire from step 3?
Any help would be appreciated. Electrical fixes are new to me and I dont want to start cutting wires if I am not confident of what I am doing. If anyone has installed this kit please let me know and offer your help.
is step six.
