Ok so i have a 84 HJ60 with the 2h with about 270000km on the odometer. I have owned it since it had 267000Km on it. I noticed it was running kinda hot (stock needle right under "H"). BTW i live in arizona and this is the month of record temps 116F is not unusual. its been about 108F our or so pretty steady and l like to drive with my AC on... =D
Here is a list of things ive done to "help"
1. Installed a glowshift pyro. drill & tap right into the manifold junction where all the cyl pipes come together.
2. Did some basic inspection and maintenance type stuff: De-sludge the engine, fresh oil, fresh fuel filter, fresh air filter, fresh oil filter. Oil pressure hangs at about 2/3s cold 1/3s hot, wanders to 1/2 when rev'ing up.
3. I performed a Radiator flush in which I followed a "similar" procedure to some guy on mud here who has the most detailed engine flush thread ive ever read in my life (thanks to that guy by the way)
Ok here are some things ive noticed:
1. With out flooring it, but accelerating, the pyro shows EGT exceeding 1400F super easy.
2. Driving in 5th highway speeds stock temp needle climbs towards max and likes to hang out. EGTs hung about 1000 or more.
3. Driving AC off and heater full blast isnt enough to bring it back down.
4. Normal temps seem to be closer to the low side of middle for the needle on the stock temp gauge.
5. 3-n-1 Glow shift has a digital temp gauge that corelates with the stock one. 160F in normal needle range and 190-195F when aproaching max.
in time line speak now i:
6. I adjust the fuel screw "total injection volume" by giving her a 1/2 - 3/4 rotation clockwise "there.. that should do it!"
7. this is when i flush the radiator
8. I regear the poor bastard from 3.70 to 4.56
and now....
9. EGTs now rocket to 1200 but dont really wonder past unless im pulling a hill with my 1000lb trailer. (which is sadly still a 35MPH affair)
10. Cruising EGTs Highway drop about 200F relative 1000F to 800F.
11. Engine doesnt really hit the hot zone temps stay below 190F. unless trailer up a hill thing happens.
So... here are my questions... sorry for the long lead-up, details are good no?
Q1: Service manual FU-78 Injection Pump adjustment talks of measuring total injection volume, provides a chart, and then leaves my un-educated self haning (how do i do this procedure?) all i could make of the chart was the RPMs and i dont have an HAC, i was lost after that.
Q2: Can i just keep adjusting my fuel screw clockwize till i hit my "happy number"? If so what is the happy number (EGTs)? Can i just back off till i "feel" the power loss and then back it in a little (like i do for my carburated gaser?)
Q3: I have the manual, but im too dumb to know how to use it in all cases. so, is there a detailed "tune up" thread as good as that awesome dude did on radiator flush?
Im looking to add a home brew turbo soon but need to make sure my engine is healthy as can be first ( I dont want this to wander into a thread about turbos, there are plenty on that and i can say ive probably read a good deal of them already) but i've added this detail for more context.
and if i havent said it enough
Thanks!!!!
Just searching around i have found TONES of stuff on all kinds of things about this engine and vehicle and its proven to be imposible for me to go without... Thanks for everyone's time...
and now....
Thanks!!!!
