2H overheating - $0.50 fan clutch fix!
Bright, Ontario
My 2H has been running hotter than usual on long trips, esp. bad on hot days when I use the a/c, going up to 1/2 on the gauge when it used to stay at 1/4. After cleaning and checking the rad fins, topping up coolant and making sure there's no air in the system, verifying the pump has good flow, and removing the t-stat to be sure, nothing seemed to make a difference. Finally figured out the fan clutch is pooched, diagnosed by checking it when the engine was very hot from a long drive and the fan spun free and easy. It should have been stiff from the clutch being engaged.
My temporary solution? Get a small angle bracket from the hardware store, drill one hole bigger, remove one nut from the fan mount and fasten the bracket on. Now when I go on trips over 1 hour in hot weather, I can bend the bracket into the fan clutch and it "locks" the fan in constant motion. Of course, it whines like an airplane on the Hwy. An I was surprise how much extra power it sucks from the engine. But the engine is now back to normal operating temp. I bend the bracket out of the way most of the time cause my trips are usually 30 min or less. Now to get my fan clutch replaced/rebuilt....
at least you can DIY when it comes to the swap. a shop quoted me 2.5 hours labour on that flipping job. it took me 20 minutes to take one off my parts cruiser, 20 minutes to take the done one out, and 40 minutes to put the parts cruiser fan back in....a year later she's still going strong.
Like the mighty Bob Dylan, I'm goin' electric.
Because "these times are a changin".
Now to find 24 V fans... or maybe just place two 12 Volters in series???
And I would love to find good pusher fans so I could place the fans in front of the rad.
