Hose replacement help
Portland,Oregon
Website
www.banatsurvivaltraining.com
Howdy
I am looking to change the smaller hoses on my 1993 TLC because of a leak next with the battery( I hope ) and I don't know if I need to use hoses made just for TLC or I can use any heather hose ( any other suggestion here), what size are the hoses and how to work on that hoses that have a copper fitting ( I believe is a copper fitting). I will past some picture to have a better view to my problem). Thank you!
:beer:
Those look like power steering hoses. The first two pics show high-pressure swaged fittings, not something you can do at home and difficult to get done professionally. If you can verify that the leaking hose is a low pressure return line, you can cut off the metal tube and clamp a regular hydraulic hose on there with hose clamps. I've done that before. You can't do that with the high-pressure hoses, probably best to purchase them already made up. If one end of any hose has a regular hose clamp, that hose is not a high pressure line, even if it has a fancy swaged fitting on the other end.
Just FYI, the small hose with the metal fitting in the first 2 pics is a hydraulic hose for the power steering. So no heater hose would work there. I think I would tend to go OEM, that way you know the hoses will fot correctly, and the originals have lasted ~16 years, so they are pretty durable.
If I get the right hose will be a problem to install my self? It's the same procedure like installing any other hoses :confused:?
How about if I will not this fixing hydraulic hose for the power steering and just add more fluid what will happen in the end :hhmm:?
Also, is some radiator leaking fluid to somewhere because I found coolant drips under radiator and I hope to be one of the hose.
Thanks!
Most decent machine shops will make you new pressure fitting hoses for less than the Dealer, plus you can get them in sturdier material and at custom lengths. Take off your old lines and call around till you find the right shop then go get a quote, I know the local place in Tacoma is pretty cheap and they do great work in an hour or so.
I will cal tomorrow a shop that working only on Toyota to see what price they have. I looked online at Baxter auto parts and they have the cheaper with $ 57.99 made by MASTER/EDELMANN, is out of stock online but maybe can be order.
Thanks
