First off Coolerman great site. I'm certainly not afraid to go after the horn button now. I'm trying to get my horn to work. I've got a new horn relay in place that when tested with a voltmeter shows 12v from battery and 12v from switch. Now it is my understanding that the "switch" terminal should only be getting voltage when the horn is depressed. Is that correct? I can get the horn to go off by connecting the Battery terminal directly to the horn terminal on the relay using a metal electrode. I can't see why the relay would be bad already seeing as how it's only ~1 month old. Which leaves the horn button. How can I test for continuity at the horn button? Do I have to pull the steering wheel for that? I should also say that the relay had gotten very hot when I was working on the horn yesterday. Not sure why it did this, but I thought that it might not have been grounded properly?
