[quote author=CruisinGA link=board=1;threadid=15601;start=msg151269#msg151269 date=1083797859]
I've driven and talked quite a bit with two people runnin holley's on 2F's.
Both of them said it took 5 years of tuning etc to get it perfect.
Both are very good mechanics.
Both cruisers run like a dog with its tail on fire.
I can settle with new stock carb over 5 years of tuning.
[/quote]
Tard!
I am one of those mentioned and it really did not take 5 years. Only 2 to get it just right. My 40 will run on its side, great MPG, more power than you can believe.
I know nothing about Hollies except the 7448 350 CFM and I assume the 500CFM is about the same. You must have a side hung float, spring loaded needle and seat, open the gap on the accelerator pump a bit then mess with the throttle cam. You will need to extend the vent tube then get it to have a very low fuel float level. You ned to get the powervalve blowout stopper (technical term??) and mess with the power valve settings. I "think" I use a 13.5HG valve but cant remember it now for sure.
It can be frustrating to get it set up correctly but once you are there it is the best carb available.
Having said all of that I will not install it on customers trucks. Too much dicking with. I really hate webbers and have yet to see one work as well as the Holley. I would buy a rebuilt stock and go with it.
