Holley Carb
Hello
I just bought my new(used) holley carb for my cruiser. How do I find the model number out? There must be 20 different numbers stamped or painted on it. I need to replace a part and it needs a rebuild as well. What should I be looking for. I would love to get it on my cruiser some time in the near future! Thanks
There should be a number on the bell. That should get you what you need.
Typically the Holley's are the standard 2 barrell 350. Basically any rebuild kit for a mechanical (350 or 500cfm) 2 barrell will work. No one knows about them because they typically have a rotten reputation. That is undeserved. I have one that ran my cruiser to the max angle that I was really comfortable at for a very long time.
What needs to be modded on it? I might have the part you need.
If you are going to rebuild it you might as well put a spring loaded needle and seat, a side hung float bowl (typically the float is a front hanging unit, bad for hills) lower the float level, put a breather extension tube on it and if it needs install a power valve blow off kit on it.
All of this is Cheap..
The holley is an excellent carb if tuned properly. Asin cannot compare in HP...
so mace, what all modifications are you talkin bout?
different float bowl? do tell.
i have a holley 2brl, and don't have any problems with it, other than i can tell it dumps a lot of fuel (flows too much). i think that 500cfm might be a bit much for me, but if i can get it tuned right, i don't have any other problems.
i got my rebuild kit for the holley for abt 15-18 bucks online someplace. just looked up holley and then the 4 digit number on the front of the carb, just above where the metering body attaches.
malphrus
The model number for a 350 cfm holley is 7448. That model
number is stamped on the air inlet flange at the top front
of the carb. Dont know the model number for the 500 cfm
holley...sorry
JimK
i want to say 4412?
just a number that stuck in my head
malphrus
Thanks for all of the replys. It is a 4412 . Is this a straight bolt on. If it is a BIG PAIN IN THE A** then I will stick with stock and sell it. How many of you guys run a holley? Thanks Again
I've driven and talked quite a bit with two people runnin holley's on 2F's.
Both of them said it took 5 years of tuning etc to get it perfect.
Both are very good mechanics.
Both cruisers run like a dog with its tail on fire.
I can settle with new stock carb over 5 years of tuning.
The 500 cfm holley 2 barrell is too much for a standard 2F. All it will do is dump more fuel into your motor than it can burn IMHO.
Hell my turbo'ed 2F only has a 460 4 barrell on it.
Like I said, there are multiple types of float bowls
One that has the inlets at an angle / \ of sorts, they have center hung float bowls= bad for hills...
kind of like this
then there is the more square type. Which is the side hung unit (not as good for running around in circles...
It did not take me 5 years to get the carb right. Much less in fact.
Power valves were very problematical in the older units, once you had a backfire through the carb they were usually junk. That was solved by a little check valve on the newer units. And the older units could be retrofitted with the blow off valve.
Thanks
My float bowl is angled like. Still I ask is it a srtaight bolt on or is there alot of Mods to do..
Mostly a straight bolt on with the proper adapter.(goes between teh carb and the phenolitic (sp??) spacer)
And a acc cable instead of the linkage.
yeah, there is an adapter. (i have one from downey)
malphrus
oh, i run a holley too, ha ha.
malphrus
Do you have a pic of the required cable and or a part number say from Napa or? So is the consensus Holley 4412 is good, bad ,better or worse than stock. Thanks Again.
never had stock on the cruiser
the holley is very simple compared to the aisin though (i have a couple of both sittin in my room).
the holley is also goin to put a lot more fuel thru than the stock. (i can't remember if this has been discussed already in this thread or not) like 500cfm v. ~330cfm
malphrus
I am not a great carb repair guy. My 77 is my DD and I offroad it. I wanted to rebuild the holley but 330 to 500 is a big difference. I would buy a stocker if I could get it cheap. My local parts stores dont carry a rebuild kit for it but found one on ebay. for the holley. Should I stop before I begin and find a stocker and rebuild it? I want to here people opinions. If I am going to be F*****g around with it to make it work then It is more work than required. Please give me you opinio. Thanks
buy a rebuild kit off ebay, maybe 20 bucks.
just get one cheap and have some fun with it. that's my suggestion. as long as you keep your expenses to a minimum, it's hard to get angry
malphrus
