- Joined
- Apr 2, 2005
- Threads
- 43
- Messages
- 138
My HJ60 2H is starting to burn a lot of oil and the clutch is starting to chatter. It has 400,000 km’s on it so that’s not too surprising. I want to go through the engine from top to bottom to find the cause of excessive oil use but I’m new to diesels so I would appreciate any tips or hints you guys could give me. Before I start I want to have everything in place so I can diagnose, replace, repair, etc as quickly as possible to minimize my down time. I put over 1000 km / 600 miles a week on my rig. Oil changes are killing me. Should I go to a bypass oil filter system? What brand? I’ve got the Toyota Engine repair manual so I’ll do the step by step they outline for engine tune-up. However I do have some questions.
1. Valve adjustment- What is the easiest way to turn crank to adjust valves. Not much room to get a socket in there. Looks like I’ll have to remove the clutch fan and rad shroud?
2. Engine compression tester – I’m having trouble finding one for a high compression metric diesel. Can someone point me towards a retailer?
3. Injection pump diaphragm, easy to replace, necessary to replace?
4. Any excellent diesel mechanics in the Calgary, Alberta area?
5. Best place to get a clutch and throwout bearing?
Any other filters, procedures, areas of concern, etc that I should do?
Skoki
Skoki
