Hj47 Disc brake conversion.
876 Cruisers
KZJ70/FZJ70/HJ47/HDJ80²
Jamaica
I have recently acquired an HJ47. I am looking at doing a 60 series disc brake conversion. What I want to know is will it just bolt up? Is there any differences?
I've seen couple posts talking about small bolt pattern and large bolt pattern and I cant seem to understand what exactly they are talking about and if that makes any difference when doing the swap?
I have also heard that the axles come in 2 different size knuckles.
I would like enough info on these as I don't want to end up wasting money. especially seeing where I am located the parts are harder to come by and to bring it in is a bit costly.
Thanks in advance,
Dan
79+ are large bolt pattern.
Disc/newer fine spline birfields are slightly larger. On pre 79 axles you'll likely need to open up the inside of the ball to allow the birfield to fit in.
60 knuckles should be straight forward to bolt in. Worst case you'll need to separate the birfield from the axle and use the 47 inner axle with the 60 birfield.
@bikersmurf thanks for the reply. I'm still a little lost as to bolt pattern. What are they referring to with large or small bolt pattern?
Any possibility to add a picture or 2 to show me what its referring to.
Just trying to widen my knowledge on these
Sorry still a little new to the mechanics on these things.
HJ47s started 8/80 the same date as the 60 series so should have the same bolt pattern on the knuckles. Same Birfield as well. Now if the HJ47 or 60 series were put together somewhere besides Japan or had things switched at some point that may not be true.
Thanks a lot for that. Now I understand.
No worries... I had to figure out most of it by trial and error... and talking to people. It’s so much easier now, but I still remember learning it too.
