Looking to buy a hitch for my 94 LC and looking for recommendations. Are all hitches just the same? My plan is to do some light towing with a max of 2500 pounds (trailer and cargo).
TIA
TIA
Note: This feature currently requires accessing the site using the built-in Safari browser.
TIA
In the picture below you will see a 2" ball/hitch that fits into the factory holes on the bumper. I took it off shortly after I purchased my 80 and replaced it with a Class IV hitch receiver. I think the PO used it to haul around his atv on a trailer - not sure.
If you are only going to tow pretty light loads, then you are more than welcome to have the one I took off - you pay shipping which should not be that much. It is only taking up space in the garage, and I would rather just give it to a fellow cruiser than sell it.
According to this thread it's 12x1.25
https://forum.ih8mud.com/80-series-tech/12031-bumper-holes-trailer-hitch.html
I just installed a Curt hitch on mine a couple of weeks ago.
http://sitepro12.sitepro.com/masterlibrary/13089/installsheet/CM_13089_INS.pdf
Easy as pie. Very similar to the Drawtite. The only drawback is that it sticks out of the vehicle for a good 4-6" or so. Other than that, it is very sturdy..
See below on thread size - only two of the 4 holes are threaded. For mine, put grade 8 hardware 1/2" in the two that were not (bolts and nuts and lock washers.My search powers are weak today. What is the thread/size for the factory four bolt location. I know its the same size as the bolts for the tow hooks (removed them to remove the Drawtite Hitch).
Also the bottom don't have capture nuts like the top. Are you guys just tacking in some bolts there?
Ill keep searching around, but in the meantime thought I would ask in this thread.
Thanks
