hitch pin pulled
any one running with hitch pin pulled how do you like it and do you have problem
I haven't done it myself but Logan (alkaline747trio) does. Gave him quite a bit more flex. I think me managed to pop out a 6" slee spring that way also. But he might post up and prove me wrong.
I run it like that all the time now. Got tired of putting it back in, so I have gotten used to the extra roll on the street. I also think there's less stress on the control arms- but that only matters on the trail when it's flexing. It makes a big difference on the trail, even when the trail isn't super rough the ride is much smoother without the front of the truck following every change in camber. I have never done any measurements to find out the exact amount of extra flex, but the overall effect is fantastic. Of course, if I break the other mount or something and the axle wraps I'm going to regret not running all 4 bolts. At your own risk, as they say.
A few questions???
I have a few questions about doing this Mod:
1. Does it allow MORE flex or just flexes EASIER?
2. If it does flex MORE, do I need extended brake lines before I do this mod? (I don't have OME L shocks yet, just the standard OME shocks)
3. Is it necessary to remove (or disconnect) the front swaybar to get the most benefit from this mod?
Thanks in advance for your opinions and answers as I value them highly!!!:cheers:
the most difinitive (as in real data) on it allowing more
https://forum.ih8mud.com/80-series-...el-pics-lift-changes-sway-bars-reference.html
With your lift and tires i'd say get the exteded brake lines before doing this.
It depends on you setup, all will flex easier, some more.
On the '80 the suspension travel is determined by the shocks. If you can get full travel now without brake line stretch, then nothing will change, unless you change shock travel.
3. Is it necessary to remove (or disconnect) the front swaybar to get the most benefit from this mod? ...
The sway bar increases flex spring rate, so if disconnected will flex easier. This mod also decreases flex spring rate, so it's up to you to tune how you like it.
If your running stock arms, especially with lots of caster correction, this mod will allow the single bushing arm to hit the tie rod, often hard enough to bend it and put huge loads on the steering parts. It's on you to test and make sure it will work on your setup. In my experience it doesn't work on lifted rigs with stock arms.
Tools,
Can you explain what "flex spring rate" means?
I am working on my quick disconnect swaybar, but I might be missing something.
Spring rate is how much force it takes to compress a spring. Flex spring rate would be the force it takes to compress one side while the other side is not being compressed. The sway bar resists flex, so it adds to the spring rate when flexing.
Tools,
The amount of force required for the axle to flex or the body to roll, it's the same thing. Easier axle flex equals more body roll (sometimes called sway) when high speed cornering.
Also the bushings are a big contributor. My guess is, it takes a large amount of force to compress bushings like this.
Tools,
What is your definition of "lots of caster correction"? I have Slee's 3* blue bushings installed. Will the bushing arm hit the tie rod with this much correction or should I be okay?
I guess I will try the mod and test it out slowly. I might try this weekend and take some pics.
Tools,
My guess would be, maybe.:hillbilly:
The bushing pic above is a buddies rig with J's, L's, OME bushings and 1.25" front spacers. When the bolt is removed, the arm gets into the rod pretty good, so he doesn't do it. The shorter shocks may help in your case?
That is the best bet. The highest chance of interference is when the unbolted side is drooped. Also steering angle has an effect, so turn the steering when testing.
Tools,
The issue with caster correction bushings in general are they are not very squishable. At least not in one direction, look at tools squished bushing, then offset the bolt all to one side like caster correction bushings.
That is an OME CC bushing. At rest the bolt is at the top of the bushing, so major squishage.:hillbilly:
stocks are much more soft and allow more flex ( less resistance to flex ) and last longer under flex conditions than OME ( with age they develop some seriour cracks .. )
I have run OME's, Blues, stockers, and now one stocker and one OME (to reduce caster plate correction slightly).
I have never noticed any different in available flex. Poly actually takes deflection (squishing) pretty well, it's twist that it has a hard time handling.
OME's poly is quite soft. Pick up one of their 10mm coil spacers and you'll see what I mean. It wouldn't take a massive amount of force to deflect them when you are talking about the weight of the axle they are attached to.
