Hiss
San Juan Puerto Rico
Website
www.facebook.com
Sometimes my truck makes this hissing sound, like a short hiss, like air escaping from a valve. Sound comes from the right side. Could it be the charcoal canister?
That's on the left side for US models.
3FE has a canister on the right side, or passenger side.
If it happens with the A/C on...listen closely in the area behind the glove box where the evaporator is housed.
The TXV (Thermal Expansion Valve) can make a short hissing noise at times....particularly if the refrigerant charge is a bit off.
When the engine's running?
After you shut it down?
When you press the brake pedal?
Jeebus; throw us a bone here...
Engine running...
How about a vacuum leak? Check your hoses.
I found out in another forum that the noise comes from the canister.
Working on very little here. Mine made a hiss while running, and a few seconds after switching off. Searched for some time. I found the seal on the booster had gone. The small one behind the master cylinder. Toyota wanted to sell me a complete booster. Crazy money.
Had a seal made job done.
