I'll look at pulling it off tomorrow after work to give it a closer look I suppose. If the turbo is bad what would be a good sign of that other than like the shaft being very lose; which it doesn't appear to be.
Don't pull it off unless you know for sure there is an issue with it. Does it spin freely? Do what Ian said. Also, by revving your engine, you should hear it spool up a bit. Watch that nothing gets sucked in tho. Can you give some pictures of the other side of your engine? Did you check the boost compensator on top of the injection pump to make sure the vacuum hose is attached to it ok with no holes?
