Highway temp trouble
I wouldn't be concerned with those temps, but if you really are:
replace heater tees, drain (via block drains) and flush your whole system a few times with distilled water, replace t-stat, and replace coolant with Toyota red or Zerex Asian. If **I was** going to all this trouble, I'd also pull the radiator and really get the fins cleaned out.
Agreed. If I go to this trouble, at a minimum I’m removing it and cleaning. I might be hard up to convince myself that shouldn’t replace it, if it out of the rig already.
Waterpump cavitating was my first thought. When I bought my FJ60 back in the mid 1990's I replaced every hose, coolant, thermostat, and an aftermarket cap. Took off on a road trip across Texas in July so temps were around 100F and it started running hot at interstate speed but would run fine slower. Tried another cap that made no difference and eventually made it to Santa Fe and bought a cap from a Toyota dealer. Never ran hot again.
What is the science behind this? If the pressure is too low/high the water pump cavitates? This is interesting
Glad this thread popped up. Just got back from a 3,000 mile road trip across CO, UT, ID, OR, WA. Lots of mountain passes and my cruiser does the exact same thing. Bit of background, my cruiser is pretty built up; lift, 33" tires, front and rear bumpers, drawers, fridge, rack with RTT, awning. So it is heavy going uphill (not sure if that is a factor).
Recent work in last 5,000 miles: new radiator/hoses, heater tees, water pump, thermostat, fan clutch. (Toyota red coolant flush). Checked the radiator fins before we left and they were clean.
Running a scangauge:
- Idle/in town: 188-190 F (even for long periods of idle in 100F weather)
- Cruising 50-65 mph flat: 198F
- Cruising 80 mph: 200-202F
- Highway speeds up long grades: 204-207F
Did hit 212F on a few steep grades at 65mph, but immediately dropped to 200F after the crest of the hill.
I was pretty worried at the start of the trip and even checked the coolant level every morning. It was always at the top of the filler neck and reservoir was normal. After more and more miles, it always stayed locked into these ranges. By the end of the trip, I just figured my cruiser ran a few degrees hot.
I may replace the radiator cap. I think it is original (180,000 miles).
This may be a dumb question, but what sensor is the scangauge actually reading to get the temp? Can this have an inaccuracy or go out of calibration? +/-3% could make a big difference
I would definitely replace the radiator cap if it is original. Go OEM, they are cheep.
The ScanGauge pulls the data from the ECU which gets the temp data from the temp sensor which sits near the thermostat on the back of the thermostat housing. It may be worth testing it per the FSM.
My rig is not built, so not much extra weight. But maybe there is something similar with ours, making the engine work a little harder, this creating more heat? Something to consider
I had the same issue as the OP, but my temps were a few degrees higher.
While idle or low load on the engine the temp was around 195, at highway speed or climbs usually climbed up to 205, and once got to 215 on a long climb in Chattanooga, TN.
I changed radiator cap and thermostat but that didn't fix it. Only fix was to replace radiator. Mine was in good overall shape, no browning on the top and appeared to be a Denso.
I put a CSF and the temps went down drastically and on highway they drop instead of climbing.
I don't know if with age the radiator deteriorates or lose heat dissipation properties, maybe crappy coolant leaves deposits that clogs the coolant passages (like cholesterol).
When I bought my truck it also had a yellow/green generic coolant that I flushed and replaced with red Valvoline.
As the pump spins it creates a high pressure in front of the impeller and low pressure behind which can cause the coolant to boil behind the blade and reduce the flow of coolant. The higher the rpms the greater the pressure difference. A higher pressure cap reduces the cavitation.
It happens with propellers on high performance boats also.
Did you use oem hoses and clamps with that csf?
It is happens with propellers on high performance boats also.
Would have never thought the water pump could potentially make the coolant boil.
It is only at the low pressure point behind the impeller but it does reduce the ability of the pump to move coolant. Higher pressure in the system reduces the cavitation. At lower speed there is less pressure drop behind the impeller blade.
I stopped by my local dealer and bought a new radiator cap. It will there tomorrow and hopefully I can have time to test it, after work sometime later this week. I will report my findings.
Just wanted to update with new info. New oem rad cap installed and test drive this evening. Ambient temps in the low 80’s, and ultragauge showed 192-194 mostly, 198 a couple times on slight inclines. I don’t know, according to some these temps are right in the wheelhouse of OK. I guess I need to decide if I think it’s an issue or not.
Mine hovers in the same temp zone in similar conditions.
Those temps sound about right. You want the operating temp high enough to run efficiently which is why you should only remove the thermostat in a break down situation. As long as the temp holds around there I'd just drive it.
I believe there can be a some variance between sensors so running few degrees one way or the other doesnt make it an immediate concern. Its the progression to higher temps over time that should be evaluated.
Just keep an eye on the temp range. If you start to notice the average temp range bracket up over time- months or with in the next year, consider it an early warning sign.
I don’t remember seeing any of the 200+ temps this winter. I could run it through the summer and see if my temps stay or go back down with a drop in ambient temps.
Update with questions. I did a drive this evening and brought along my new infrared laser thermometer. So I took some readings and wanted to ask if anything seems out of line here. These temps taken with ultragauge showing 192, at least the couple times I looked in the cab to check it. Upper radiator hose connection at the housing 191-192, thermostat housing 141. I didn’t have great access to the radiator but temps across the top were in the 180’s and the bottom was in the 130’s. Throughout the middle it seemed to be a general decrease from top to bottom. I didn’t notice any hotspots. These temps were taken after I got home and parked, after hitting 199 a couple miles away, at 60mph. Does anyone see anything concerning? Also anything else that I should be trying to get a reading of? Thanks again as I continue to look into this, and fail to decide if I have a problem or not.
Given the summer temps, nothing seems out of sorts.
It wasn’t as hot as had been yesterday due to rain. Ambient air temp was in the mid to high 70’s at the time, I believe.
