highway missing...
Val-David
First time on the highway this year.... and it looks like I have a fuel problem.
When going over 2000 rpm, the engine starts missing like if it was starving.
Driving at 2000 rpm in low range is not a problem.....
With the engine at idle, the fuel is at the bottom of the carb glass. Maybe the carb float is to low?????
BTW 1977 2f with 1971 carb and dizzy (with pertronix)
Fuel filter is new,fuel line is 1 year old.
What should I look at first?
Thanks :beer:
Hilarious. From the title I thought you went to get on your normal highway and it was suddenly gone!
From your description I'd start with engine timing and electrical (spark plugs, gap, wires, etc.). Less likely to be starving fuel IMO.
nope...the highway is still there :D
I just did the routine maintenance with oem parts...but I know new parts can be deffective (don't ask :mad: )
is it normal that the fuel is at the bottom of the carb's glass at idle?
is it still possible to get a fuel pump from toyota... if yes, anybody knows the approx. price?
so I don't have to care about the fuel level of the carb? How should it be at idle?
Yes you need to care about the fuel level in the carb, it should be halfway up the sightglass. Even though you replaced your fuel filter does not mean you don't have a fuel restriction. Old cruiser tanks are real good at producing tons of hose and filter clogging rusty nuggets. Remove the hose on the output side of your fuel pump and put into a collection device (soda bottle). Now turn over the engine, you should fill that bottle pretty damn quick if you don't have a problem with fuel delivery.
If you don't get a steady strong flow of fuel you know where to start looking. Unhook the line from the pump to the tank and use compressed air to hopfully unclog it. Your pump could also be bad. If this is the case you are probably pumping tons of raw gas into your oilpan due to a hole in the pump diaphram.
If it is pumping plenty of gas then your carb float is set too low to begin with and you may have other carb issues. Since I hate messing with the carb I test the other parts of fuel delivery first.
If your truck has been sitting for a while, the float may be stuck. Measure the fuel pump output first. It should be able to pump about 100 ml in about 20-30 seconds of cranking. If the pump is OK, then spray some carb cleaner into the fuel inlet and rap the top cover with screwdriver handle. Reconnect the gas line and see if the fuel level is OK and the problem is gone.
thanks! your help is really appreciated, I'm gonna look at it monday and post for updates....
