Highway bucking.
Rixeyville, VA
First off,
I did search around and got a few things i will check asap but just wanted to post this up and see if anyone could offer some helpful advice.
I've battled a highway jerk/buck in an old 40 i had and easely solved the problem with a new fuel filter.
My 78 seems to be having a slight problem where it begins to buck at about 70mph or so. Now, i realize 70+ isnt exactly safe in a big 40 but its still a problem nonetheless and with a lengthy trip coming up i want to resolve it now.
It started about a month ago when i got it, bucked on the highway at about 65mph when i hammered the gas. I replaced the 2 fuel filter and up'd the fuel pressure regulator from "3" to "3.5". This helped a little but now the problem happens at 70 and above.
Any advice on what to check? I will check all rubber lines tomorrow and make sure there isnt a third filter hiding. BTW, the truck is running a weber 38 and is smooth at 65mph all day long. I just dont want this to turn into a bigger problem 5 hours away from home.
Thanks.
The bucking you describe is most likely fuel starvation. 38mm Webers are pretty thirsty carbs. You might find that you need to boost your baseline fuel pressure.
You can start by eliminating the regulator all together, just to see if your present fuel pump is even capable of the meeting the fuel demands at 70mph without regulation. If it is, you might want to consider leaving the regulator off. If you are still experiencing bucking, you should consider replacing your fuel pump.
