high oil pressure
fred you seem to be looking to have a meaningless argument here by using increasingly patronizing language and drawing increasingly insignificant distinctions. if i was inclined to continue I could certainly suggest you were spreading "misinformation" by describing my motor oil as 40 weight and that you are now getting desperate in the hairs you are splitting with me to try to sustain an argument, but i think it is pretty clear that we both know enough about what we are talking about to make informed choices about motor oil even if we are using slightly different terminology.
your point seems to be that I should use a 0w30 not a 0w40 because 0w40 is overkill. i disagree. i use 0w40 all year round. i actually live in a desert and it often gets over 100 degrees up here in the summer, and i am also often down south. my truck also runs slightly hot all the time. plus, 0 weight synthetic is hard to come by here. mobil 1 only comes in 5w formulation unless you special order a case.
and to try to help you a litte, on why folks might think the 0w40 is a good oil for canada. the rotella full synthetic i use was specially formulated by shell canada for canadian use. it was not sold in the US at all for several years (and may still not be although i think you have it now).
another reason i prefer rotella is that when i used mobil 1 0w40 and a number of other oils when i first got the truck, my engine had a significant rear main seal leak and a slight leak up front and it consumed oil. the rotella has reduced oil consumption and stopped them up completely for 40,000 miles now.
if you like you can download the data sheet here. 0w40 is the only full synthetic shell sells up here.
Shell Canada Limited - Automotive lubricants: Heavy-duty engine oil
Nah, I'm not trying to have a meaningless argument here.
You originally asked about what appears to be high oil pressure and I asked why you where running 40 (for the high end), as that can certainly increase oil pressure over 30.
Regarding heat, I live in Tucson Arizona and we get really hot here in the summers, with the air temperature (in the shade) regularly over 110*, so I'm very familiar with heat ;)
But I'll leave you alone to run what you wish.....
Anyway, for those interested, here's an great explanation on engine oils, one of the best that I've ever seen. He's got it right ;)
FerrariChat.com - FAQ: Motor Oil Articles by Dr. Ali E. Haas (AEHaas)
Fred
The relief pressure on mine has always been the same as the picture CPG posted.
If your oil pressure does show up high via a mechanical gauge the only cause can be in the oil pressure releif valve, there are 3 parts to order, plunger spring and seal, Dan carries them,
It is easy to do you remove the cap, it is just forward of the power steering pump mounted in the timing cover extension right next to the oil pump. pull out the spring and then the plunger, look down the bore with a good light (may need a mirror) make sure the bore is smooth and there are no junk in there that could stop the plunger, grit, carbon metal etc, install the new plunger then new spring and then the cap with a new seal.
BTW side not when the temp gauge is reading high temperatures the main resistor can get quite hot, this added heat will actually make the oil pressure gauge above it read differently, I I am not certain I remember which direction it throws it of but i want to say higher, It is somewhat less so on a modded gauge as the resistor does not get as hot for a given reading but there is still an effect.
oil coming from the fill cap is another matter, that can be eighter a leakign fill cap seal or an indication of high crank case pressure, you are already on the trail of that on, check the other PCV hose wile you are at it,
my alway between 3/4 line 2,500rpm i use 10/30 dino with 267,000+mi. 0rg h/g
Semlin-I had the same worry. My cruiser seems to suffer from high blood pressure too, lol. It runs exactly like yours and has run that way since I bought it 20,000 miles ago. I am at 203,000 mi. I assume by gauge is just a little screwy. As long as it remains consistent I'm not worried about it.
Mine does this and every once in a while (usually under accel) it will actually kick on the "idiot light" too? The needle seems to be about this same location?
What "could" truly high pressure lead to? I will be towing the 5k camper to the beach in about a month so I am wondering what will happen "under load" if I am getting this now.
I will have the mechanic slap a real gauge on there to test if possible (I want to get a real tranny temp gauge too since it will be used to tow a few times a year)
Sam
Go to a shop and get some one to hook up a mechanical oil pressure gauge or a real good electrical one(or just buy a real good one). The stock Toyota one is just a step up from a idiot light(imho). Then maybe you will be able to see the values a bit better. As for the oil, I personally would not use a oil that is not in print for the 1FZ. I have not seen where 0w-20 is a oil accepted by Toyota's engineers for the 1FZ. I have not look in a while but have not seen it. But I have seen 0w30, 5w30, 10w30, 5w40, 20w50. I do understand that there is engineers that spec the lower viscosities for different engines. I have not read this article that Fredtj suggests, but may. I have read articles in the past talking, but again did not see toyota going this direction yet.
Good luck on your choice. I think the higher oil pressure is just about the gauge and you would be better served with a guage with a value reading. later Robbie
this problem self corrected with a new pcv valve and an oil change. pressure is running slighlty lower and nothing is venting from the 710 lid.
So, get the pressure measured with a test gauge, and if your numbers fall in the 4psi to 75psi range that Toyota talks about in the manual, then forget about it. I run 15w-50 and my needle runs just above the 2/3 mark, except at idle when it runs above the lower mark by maybe 3 needle widths.
I have a mech oil press gauge paralleled with the oem pressure sender and the range is as Drew stated, 4-75psi based on rpms.
Cheers.
I had the same problem after switching to synthetic, An oil and filter swap fixed it both times. I think the synthetic was cleaning out enough junk to restrict the filter. After two oil changes all was good, and when I pulled the HG later, she was shiny inside (well kind of an orange shiny).
