ok this is a little odd. i seem to have a high oil pressure problem. can anyone think what would do this?
I have noticed all winter that under load on a hill climb or gunning it my oil pressure is sometimes a needle width above the upper hash mark. lately it seems to happen more and maybe sometimes closer to two needle marks.
last gas fill up i noticed spatter on the valve cover around my oil filter cap. i thought it was weird. checked the cap and it seemed tight. wiped it all off. tightened the cap. next fill, same thing. the cap was tight and is not cracked and I don't see how oil is forcing its way out but clearly it is.
plus, perhaps coincidentally I now have a new oil weep somewhere at the front down low that I did not have before. I have not sourced it but it is dripping onto the skid plate.
the pcv valve seems fine, but I have ordered a new one just in case.
i am running 0w40 rotella synthetic put in early last fall with about 3500 miles on it.
the engine had a valve grind and new seals with a h/g job 25,000 miles ago and generally uses no oil at all, but in the last two fills is down about 1/4 of the way to the add line.
only other thing i can add is the truck is no longer a DD. it now is generally towing, hauling or going up a ski hill when it gets out for a run.
