High...ish idle
Fort Worth, TX
I've had a 93 for about 4 months and have replaced the oil pump seal, distributor o ring, valve cover gasket, pcv valve/grommet, spark plugs, dist cap, rotor, and plugs (all OEM). It never ran terrific, but never bad either. I've advanced the timing to about 7deg and it seems to be running fine. It's not really an causing any issues, but it idles a bit high, around 1k, or 900 when in gear. I understand that there is no way to adjust idle, but would this indicate an underlying issue?
I've checked for vacuum leaks and leaks in the intake tube and haven't found any. I've also tried disconnecting the battery multiple times. Gas mileage is around 11mpg with mixed driving.
Any thoughts on solutions or other things to check? I do have a FSM....
Sent from my iPhone
or the throttle cable could be too tight upon reinstall.
The system works as follows:
There is really only 1 idle air control bypass - and this is controlled by the stepper motor (electronic). When you first start the car - the increase in RPM is based on a mechanical vacuum valve that is held open without vacuum. It has an armature (which is also adjustable - this could be your source as well) that mechanically pushes (from the backside) the throttle plate open. Once vacuum builds, the valve 'closes' and the throttle plate closes as well. Idle is then controlled by the stepper motor (this can literally be a step that takes all of about a second maybe 2) electronically. If your AC works and you kick it on - then your idle jumps up (or doesn't drop significantly) then your stepper motor is probably working fine....
So the things that could affect idle are:
Vacuum leak (least likely as this is an AFM year - and that would cause significantly worse issues)
Throttle cable to tight (mechanically holding the throttle plate open)
Incorrectly adjusted vacuum valve pushrod/armature
Incorrect vacuum line run to vacuum valve (or none)
Bad stepper motor
here's a pic, just cus. BTW, I think the high idle is the primary cause of the stink bug stance. Maybe spacers will resolve the idle issue??
Sent from my iPhone
Bad stepper motor
Could you further explain the "mechanical vacuum valve that is held open without vacuum" statement? I don't have a high cold start idle any longer. I've got a long thread going where I still haven't figured it out. I didn't realize there was another "system" involved in the high idle at cold start besides the IAC.
No More High Idle on Cold Start
This is a 93/94 FZJ throttle body that's been removed. The diaphragm under the tps (electrical sensor on the right) is a vacuum controlled fast idle. There is a vacuum line that runs to it from the TB. Basically, the diaphragm is held open when there is no vacuum - and the armature physically pushes the throttle body butterfly open (through external linkage, which you can see here). When vacuum is present, the vacuum pulls the diaphragm towards the vacuum line, and mechanically pulls the armature away from the linkage, and that initial fast idle is stopped by closing the TB. At that point, it should be controlled from the IACV. The IACV is removed from this photo, and when removed looks like:
this one has a crack in the housing, as you can see.
Thanks for the explanation. I knew about the IAC and TPS but never realized something else initially kicked up the idle before the IAC could come on-line.
I pulled the throttle body off yesterday and checked and adjusted the TPS. I put the cables back on and noticed that it would be pretty easy to have the cruise cable hold the throttle open if it was too tight. I think this may have been my problem. I'll give it a day or so to let the ECM relearn and report back.
Sent from my iPhone
