Background:
I recently retrofitted a set of Morimoto MLED 2.0's in a set of OEM LX470 headlights. This means that both my low and high-beam harnesses plug into the control box and run off of the single projector. Throughout the retrofit I have tested everything and never noticed any issues, but I never had them on longer than 10-15 minutes. Previous to the retrofit, the headlights worked with no issues.
The problem:
Sometimes when I turn the truck on with the headlights set to "Auto", only the driver-side high-beam will stay on. If I turn the headlight stalk to OFF, that same high-beam stays on. If I turn it to "-", it stays on. But if I turn the stalk to "headlight on", both headlights turn on as they should. Like I said, this is intermittent. Sometimes it doesn't happen, sometimes it does.
What I've tried:
I have unplugged the DRL box in the engine bay. This didn't fix the problem.
Before I go back and double check the wiring harness, has anyone experienced something like this before? Thanks!
The problem:
What I've tried:
