Hi-Lift Jack points
Utah
Ok so i got myself the X-TREME hi-lift Jack. Looks great, now due to my lack of research into it i have questions. How and where does the damn thing hook up. The jacking arm seems short to hook up to any point that is of the frame of the vehcle, beside the 2" receiver mounting bracket. I ordered the attachement for the wheels, but dont know if it will work with a stock rim. :rolleyes:
It works great with any of the solid steel front and rear aftermarket bumpers which you will now need to buy. They do make a hook type arrangement that will probably work on your standard bumpers but I've never tried them.
If you don't go offroad and don't have a lift, there's no real need for a HiLift jack to change a tire.
... there's no real need for a HiLift jack to change a tire.
Agree, I have never used a hi-lift on my '80. Have always used the stock jack to change even the 37" tires.
Sliders make a good side jacking point.
When you use a hilift you run into the problem of the suspension unloading before lifting the wheel off the ground. Those adapters that hook onto the wheel are great as they get around this problem without fiddling with limiting straps on the axle. Although they make changing tyres one step harder as you have to jack it up, support the axle by some means (ie a log) and then lower the jack.
Having said that, having the limiting straps on the axle is also useful when you are in a position where you can't get the hi lift next to the wheel.
Slee has a pretty nice solution for your problems. Works well with sliders and all bumpers with eyelets. Also includes the hooks for lifting by the wheel, and a strap for the axle. Worth the money to me. Plus put the money into the Hi-Lift base, as it too does help to keep things steady.
Slee - Recovery Gear
:cheers:
Steve
Well the reason I bought it is for me and my gf when we go on overland trips anywhere from a couple of weeks to month long. Id be by myself in the wilderness and if it does get stuck I want some kind of means of recovery even if it does take me hours. That's why I bought it, I also don't have no winch.
Much is made of a HiLift's use as a winch, and if bullets were zipping overhead or wolves were howling in the distance, that'd be fine I suppose, but I can't imagine anything more tedious. Before I did that, I'd whip out a credit card and buy a winch. If you're going into seriously remote country, you need the tools to do it, otherwise you're just begging for pain, and inviting your friend along for the ride.
After a friend rolled his 40 we used my 80 to pull him back onto his wheels and then we used his High Lift to move the back end of the 40 to be in line with the hill, so he could coast back down onto flat ground. We were then able to assess his engine for damage and he drove home.
All of that being said, given the fact the neither of us had a winch, we were very glad to have the High Lift jack to help us out of the mess. Please note that had he gone out by himself, the truck would have been still laying on its side and we would have had to hike out and get help.
What I learned was that I REALLY want a winch so as to not use my drive train to pull someone else upright and not to go out by myself. Good luck in you adventures and here is a link to video footage of the 40 rolling.
YouTube - ‪FJ40 Land Cruiser Rock Climb & Rollover‬‏
I dont think a guy requires a winch to go for an overland trip especially if its just for 2 weeks this time. I dont even know if u can call it overland, more like extended country trip. Im not planning on going into anything that will need a winch while i realize i dont have one. But i did want to have a hi-lift jack, just in case things go sour. And worst case scenario i will use it as a winch. A stuck 6000LBS is a lot to move. Ive also read lots of expedition stories of people travelling for years across continents without a winch. just saying
great tool
I have a winch and I still use my hi lift at lot in the winter in deep snow :p, especially jack on the wheels, works great.:D
Get a tirfor/come-a-long hand winch. Less effort than a HiLift as you don't have to keep resetting every 3ft and you can do a double line pull fairly easily with a snatch block.
Still more effort than a leccy winch, but more versatile.
One man's overlanding is another man's daily commute. Just like wheeling means different things to different people, so does overlanding. For me and where I go, I want a winch. And I high lift.
Is it worth having a Hi-lift with a tire lift mate for a stock 100 series?
The question with the lift mate is how it will work your wheels. I found on the 80 I didn't like the wheel-strap positions the one time I tried. Hard to tell until you give it a try. The tire mate would make changing a tire more difficult/impossible if you didn't have something to rest the truck on while you actually changed the wheel.
Don't you know that's what large flat rocks are made for, you can use a few of them stacked together to rest your axle on while you change your tire. You'll have to forgive me but I'm going to shamelessly plug a Mud Vendor here. The better, and MUCH safer idea would be to buy one of Land Cruiser Phils factory jack adapters to support your axle while changing your tire. Below is a link to his web site along with a copy of his jack adapter page.
Jack Adapters
40/60/80/LX450 & 100/LX470 & 200/LX570 & Tundra
40 Series/80 Series/LX450
100 Series/LX470
IMG_5716%20%281%29.JPG.1552611475183
200 Series/LX570
Jack adapter stored in jack compartment
Many thanks to my wife for pointing out the need and encouragement to design a safe method for jacking our Land Cruisers.
A factory Toyota jack is one of the most reliable well made jacks available. Little to fail and works in any position but safe placement is a problem and safety concern. This jack adapter eliminates the placement problem especially when ideal circumstance are not available. Other adapter systems are available, but I could not find any to fit under an axle with a flat tire making them pretty much worthless.
If you have ever jacked up your Land Cruiser you know you need this.
  • For the 80 series one of the legs of the adapter is shorter for very secure front axle placement and to reduce the chance of slipping.
  • Adapter remains tight to axle with jack fully extended. An advantage when conditions are not flat.
  • The adapter wraps around the rear axle making placement the safest possible and very straight forward.
  • Designed to fit any jack post diameter of 1 1/2" or 2". Check your jack post size to ensure compatibility.
  • Stores rattle free with the factory jack.
  • Heavy duty fully welded construction will not distort or bend.
  • Adapter is raw with no finish.
  • Special FREE gift to make testing your new adapter more enjoyable
**ALWAYS FREE SHIPPING**
Manufactured in the USA
Jack Adapter - $37.00
Shipping is FREE in the contiguous United States only.
40/60/80/LX450 or any <2" jack post
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=U22FPFSZFJ548
100/LX470 or any <1 1/2" jack post
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=24MKHJP87MTEY
200/LX570
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=W6K2R5JA75DXJ
Gen III Tundra or any <2" jack post
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=3TTFSGKC385EE
