Hey Semlin....
Fort Apache: Victoria
When you move out of the AirCare gulag, are you going to remove your cats? I'm thinking that since the o2 sensors are pre-cat removing them won't have an effect on the readings.... what do you think?
Good Question, I would like to dumpster mine also.
The starboard slider will be more practical and easier to build. I read in another thread that it is not restrictive (power wise) but that replacing that big keg of a muffler behind it will net you some H.P. (and some ground clearance)
I want to ditch mine as well--my floor gets stupid hot. Waiting to hear if there are any negatives.
search for my name and converters...I found a single 14" Magnaflow that will replace the stock double setup for $75. If you have the double tube you could even run two no problem. They are MUCH less hot than stock, and they tuck WAY up under and sliders are a non-issue.
Worth the effort to save some emissions gear from a dumpster and is a small effort to be a little earth friendly...no performance issues (mine improved with a single, high flow cat setup).
We don't have a visual, so that's not an issue. Alk, are your sensors both pre-cat?
As far as being a little more earth friendly, I'm all for that, but it's a freakin' LAND CRUISER.
I've heard that cats only do what they're designed to do for a few years at best. I suppose a few minutes of 'net research would confirm or deny that.
-Spike
Denied, apparently. Googled 'catalytic converter life'. Seems that cats should last quite a while unless the engine is running poorly or coolant is present in the exhaust. Now I wonder how that would happen...
-Spike
Was there a noticeable change in performance? Did the change (if any) in back-pressure monkey with any readings?
to answer the question a little tardily,
my oem rebuilt kansas city converter cats only got me through aircare once. it is two years later and I can't pass and I'm getting the same results as last time. with methyl hydrate I fail nox by about 20% or 33% without it. my 3 month time limit ran out so the truck is parked until I move in 12 days and register the new address.
I am not going to bother removing the dysfunctional cats. I'd have to drop the slider to do it and I'm not confident high flow cats will fit the gap hanna made.
Dan,
Could you post the part number of the convert from Magnaflow and tell me how you handled the O2 sensors?
Thanks?
You'll sure miss AirCare, I bet. ;) And Lower Mainland insurance rates,too (mine decreased by 30% when I moved from Van to Vic).
