Help with rear wiper
Albany, NY
My rear wiper was frozen this morning and I left the switch on last night. When I started the car, the rear wiper did not move. When I went to the back and freed the arm from the ice, it was in the horizontal position, the went downward, instead of upward.
Currently the arm is floppy. I can move it back and forth easily.
So the question is what went wrong. The motor seems to be fine. Do I have to replace a part. It looks like what is bad is the car does not know where the arm is. In addition it is also loose.
Help.
it is likely a bad earth in the wire that goes from the hatch to the roof in the back left corner. do a search and you will find theads about it. the bad eartj up there causes all kinds of weird things as well as the rear wiper to play up!
The arm is attached to the shaft on a conical seat. This is a safety feature that lets the arm slip on the shaft if it gets stuck, so the motor is not held stalled and burn something out. The conical shaft has small splines in it that "bite" into the soft aluminum of the arm. All you should have to do is pop the cover off the arm pivot, remove the 12mm nut, pull the arm off. Take a small wire brush and clean the splines off on the shaft, they will probably be fouled with small aluminum shavings. Then put the arm back on, tighten the nut down.
Thanks KLF.
The motor is fine.
The arm is new from the summer and when I put it on, I used anti seaze grease so I hope that this is the problem. I know about the 12mm nut. It should be an easy fix.
