Help with newly rebuilt 2f
In the final stages of a rebuild(hopefully) and had something odd happen this morning. Got the engine to run a bit yesterday with starter fluid and was gonna get fuel in the carb and all to try and seal the deal today. Was charging the battery overnight so I had the hot side of the battery disconnected. Went to connect it this morning and had something odd happenened when I hooked up the battery. Got an immediate "bank"on the driver side of the engine compartment. Some smoke or something afterward. Wasn't attempting to turn the engine over just hooking up battery. Just to be safe I tried to turn the engine over by hand and it is very tight so I stopped. Couldn't really tell if it was an electrical type bank or a pressure release. Any ideas? Wanna proceed with caution so I don't take 2 steps back. Thanks in advance.
How much smoke are you talking about?? Did you smell burning wire? Or did your carb just cough up some gas?
if all is good, then just try turning the engine over without coil attached & spark plugs removed so it will puff some air out of the cylinders. the crank should rotate freely, and if it doesn't, then you have some more work ahead of you
either by hand or starter, rotate the crank several revolutions to get oil to the top of the valve train, before actually starting the engine
HTH
Did you leave the ignition switch in the "on" position overnight and forget to turn it off before hooking up the battery? could be just a spark plug went bang?
Not sure on the ignition switch don't remember. All plugs and wires look good. Don't recall smelling smoke. Came from the lower side of the engine. With plugs out it's still hard to turn. I've already primed oil to the top side. Everything electrical works as before.
Crankshafts don't usually turn very easily once you have new piston rings trying to seat in the cylinders. You sized all your rings to the individual cylinders to have the proper ring gaps, right? When you initially installed the crankshaft, before attaching the rods, you turned the crank by hand to make sure it turned easily. If you had proper bearing clearance on the mains, but it turns over hard, then you need to check the thrust bearing surface where it bears against the crank. This has nothing to do with the "bang" you heard, but I was concerned about your statements about the crank being hard to turn.
Yes on all questions. Something's not right and I decided the 2f and I needed some time apart. I'll dig back in next week hopefully. I finally learned that it's better sometime to walk away. Thanks all.
OK. So I've given this incident some thought and here is my theory of what happened -
Obviously, when I hooked up the pos side of the battery, the key was on, the distributor sparked and one lucky cylinder got a bang. That cylinder was at top dead center so the connecting rod and portion of the crack shaft that connects to the connecting rod were vertical and the valves were closed. The explosion caused some pressure release out of the head gasket which is the smoke I saw. The ignition in the cylinder and fact that the connecting road and all were vertical prevented the engine from rotating and broke the piston. I can only assume it was the weakest part and broke due to the force.
Next step will be to drain the oil, take pan off and give it a look.
anybody buy that explanation?
Highly unlikely. With the piston parked at TDC, all the compression had leaked out long ago, so there would be very little combustible mixture in there.
But, re-reading this thread requires pointing out 2 errors.
1. never 'just see if it will start'. Get everything hooked up, prime the oil & fuel, start the engine, break-in for 20 minutes.
2. never use starting fluid, especially on a new engine with good compression. It will break stuff.
If a spark in the cylinder didn't cause the initial "bang" then where did it come from when I hooked up the battery?
It might have caused a tiny pop, but there isn't enough oxygen in the chamber at TDC to do anything exciting. About the same as when the dissy cap ignites due to failed cap ventilation.
Running an engine on starting fluid could have smeared the piston or rings on the cylinder. Before tearing down the engine, pull the plugs and look in the plug holes with small flashlight. Put trans in 4th gear, high range and roll to truck to turn crank slowly & incrementally. Look at pistons as they approach TDC for visible damage. If no problem found, then connect battery and do cranking compression test. Values will be lower due to fresh rings not seated yet, but should be consistent and above 100#.
If you go to Banggood.com or Ebay, you can buy a tiny endoscope that plugs into your cell phone and it has a light that you can see all around inside the cylinder after removing the plugs.
I have blown up a muffler by letting fuel pool in it while cranking, then getting a spark that set off the whole explosion thing, but it is WAY more than a pop when it blows!
Well, curiosity got the best of me so I drained the oil and took the pan off last night. Good news to report as all appears to be well, my paranoia probably got the best of me, and Jim( and my dad) were correct. Looks like the starter fluid resulted in the drying out of the cylinder walls which was causing the added resistance when I attempted to turn it over by hand. There was also a little bit of "singing" coming from the rings when moving in the cylinder due to the lack of lubrication. I added a little oil in from the top and bottom of the cylinders and now all appear to be well. Cylinder walls are still good and smooth from honing. Head gasket looks OK as well.
Lessons learned -
1. Never ever ever ever use starter fluid. Never.
2. Just get some fuel in the carb and get it going. If you've got spark, fuel, and the timing is close to on then it should start. If it doesn't then something is wrong.
Thanks all for the on the job training. Will try to get it fired up this weekend.
