Help with LS swap
VENEZUELA-USA-SA-PT
Hi Guys so I need help :(
here is the story. Got a series 80 4.5 petrol and decided to put a LS in it.
donor car was a silverado 2012 5.3 6 speed from my company that was in a accident. So all parts are from the same car.
The swap is complete but now I have a issue.
When I was doing the swap I sent the ECU to Black Bear Performance to have VATS removed and everything needed so that when I had the car done I could just put the ECU and all done.
But it not was the case. I connected the ECU did the relearning and figure out the car dosent want to turn on.
after 2 days I quite and call a local tuner to discover that the VATS and all programming was still the same, so BBP didnt do nothing even if they send me a email with all the mods..
So now my tuner removed VATS and the car turned one but dosent want to accelerate. There is no signal to the MAP and pin 43 is not sending 5v signal.
So now what is my issue.. The mechanic is a pro and I bought a complete wiring kit from BP Automotive that I know that is perfect so wiring is not the problem. The tunner is blaming the wiring so now I cannot do nothing without f.. some people on the way.
I would like to know if anyone know what can happen to the tune so that this can happen.
Before the tuner touched the ECU we turned on the truck by putting directly the fuel and it was accelerating.
Here is some pics, will take more when its done.
Ignore the picture of the engine, its just to show that there is a swap there, its all done now but forgot to take picture
