Help with front shock removal
Houston, tx
93 with old bilstein shocks. Rebuilt front end due to major leakage and thought while I'm under here might as well replace shocks also. Top and bottom nuts came off but there is a flange on the bottom holding the shock in place (2nd & 3rd pic). Flange is just at top of bolt in pic. Looked in this forum, on line, install instructions at bilstein site but couldn't find anything indicating how to remove with this flange in the way. Any ideas on what I'm missing?
On your last photo the rubber bushing and metal plate will just pry off. Then just force the shock to compress and rip it out.
+1 on the pry it off. it is just stuck,
you could let the axle droop down on that side. the should free the washer and allow you to remove the shock.
