I may get pummelled by others as some do not like flushes, but I have done them to my engines, including a 3FE with no adverse effects. Personally, if I did not know how the engine was taken care of, and it appeared that it wasn't ie: conventional (dino) oil, long drain intervals, etc. I would first put Rislone Engine Treatment (yellow quart bottle) in the crankcase (with whatever oil is already in there) and run it for a few hundred miles (do not overfill). I then would add a 5 minute engine flush (take your pick, CRC, GUNK brand, KW, etc found at any parts store, Walmart etc) as it says, 5 minutes before you change your oil. Do not drive the engine after the flush is added; so do it in your driveway if you change the oil yourself, or do it in the parking lot that is next door to your favorite Oil /Lube shop. Tell the lube guys that you just put a flush in and and ask them to please leave the drain plug out a bit longer to be sure it all drains out.
I would then use conventional oil (not synthetic) as the fresh fill with new filter and repeat the above process. Leave room for the Rislone (1 quart) if you are going to repeat this process again. Do not overfill. Run it again for a few hundred miles, flush again. It should be clean by now, then you can add the synthetic of your choice. Mobil 1 High Mileage is a common choice. A good filter is also important. Can't go wrong with Toyota brand. I have also used the Mobil 1 Extended Performance filter with good results. (Read the current thread on the 20004 Toyota filters and the FAQ section). You may initially get more leakage or seepage with the Mobil 1 IME, but as the seals and gaskets get use to it, that should taper off, IME. If you continue to leak/seep a lot of oil, have it looked at by a mechnanic who knows these engines; it may just need a new oil pan gasket.
