Help with dirty oil?
Do you think adding the oil addiative for cleaning purposesses is a good thing?
Listen to this gury Gray...I did what he rec. a few months ago about desludge my 200K engine. She ran smoother and seems to decrease usage of oil burning.
Mine was burning about 1/2 to 1 per 1000 miles. It slow down some, but now my damn arch is leaking and send the oil back toward the oil pain..uh oil pan(been in the office all day seeing patients) lol.
I wonder if I should try the rear main seal BAR stop leak for the arch??
I do agree with some that say that engine flushes may increase leaks/seeps from the FIPK gaskets. The way I look at it we have a choice, run a sludged up engine with no or slight seeps, along with poor performance and more internal oil leaks (burning/blow-by) or, desludge the engine and risk slightly more seeps/leaks, and in the process, get a smoother running engine with possibly less internal oil losses. Take your pick.
Regarding the differential cleaning/flush; I did a lot of reading and called about four different companies to talk to their techs before I decided to use an engine flush product in my differential. No one makes one specifically for an automotive gear box. However, for industrial gear boxes ie: inside a factory, they sometimes use a light weight turbine oil for cleaning, Mobil makes one. The reason I wanted to flush my diff was that I had a large amount of Moly grease contamination, and as everyone knows, grease is hard to clean up. From everything I read and heard, the seals (pinion and axle) would not be harmed by the chemicals in the engine flush products as they are just made of standard seal material, as long as the flush is not left in. So don't leave the flush in for a long period (sitting or moving) and do not run it too long as it will obviously dilute out the gear oil making for less effective lubrication; hence the 20-30 minute drive time, as well as the second fill and drain, to get out any remaining flush or grease. I have no proof that my technique does a better or worse job of cleaning out the diff than just using gear oil and changing it a few times, but being someone who likes to live life on the edge, I went for it.
Ok gray Im sold. Thanks for the explanation. When I picked up th egear oil from Checkers. The kid there told me he adds a qaurt of transmition fluid to his engine oil. Let it idle (no driving) for 20 mins. Then flushes it. Claims the tranny fluid has detergent that cleans the engine. Better not post that remedy. GUYS WOULD FLIP. Your thoughts?
I've done that on a Ford. Still works after 15,000 miles. [insert sarcastic comment here]
Personally, I would not use ATF in the engine or anywhere else, other than the tranny or power steering boxes. The seals in trannies are different than the seals in the engine or axles. However, I have heard of that trick of using ATF added to a sludged up engine to clean it out for 40 years; just never tried it as there are specific flushes made for engines. I have a slight amount of seepage on my front and real seals and/or oil pan gaskets, but the engine (with 249K miles) only uses/leaks ~1/2 quart per 4000 miles using Mobil 1 10W-30 High Mileage oil. There is one engine flush that is supposed to be very gentle on gaskets, made by LUBEGARD. I have never used their engine flush, but have used their other products, like their Tranny flush; seemed to work well when I cleaned/flushed my tranny a year ago.
Gray what time of engine flush did you use to clean your diff?
The brand was either CRC or Gunk engine flush, the time I left it in was 20 minutes or so of gentle driving ie: no overly aggressive accelerations and no high speed highway. I drained the contaminated (with grease) black gear oil (front only) then added one quart engine flush and two quarts cheapo gear oil. Drove around, forward and reversing a few times, not too fast, mostly low speed around 30, but some up to 55mph, for the 20-30 minutes total, then drained it out. etc as above. The first drain was pitch black, the second (just gear oil) was tinged black, the third was essentially normal (after 1500 miles), then I put in my synthetic. I only used the flush once in the first fill. It is likely that there could be more grease stuck on the inside walls of the axle housing, but I think I got more out than if I had just used gear oil.
Ok I I drain it out today. Looked like ink. The fill was quite the job. Finally ran some 3/4" tubing down through the engine compartment. Got her filled up. Think ill drive it a hundren miles or so drain it. And depending on how dark it is, I do the engine flush trick. I can't thank you enough for all you input. I think I've changed my oil once twenty years ago. So this is all knew to me. Thanks again!!!! OH Do i need to do teh swame for the rear. The first week I owned the truck I had a shop change the rear gasket.
The rear diff and the transfer case IME/IMO doesn't need any special cleaning (no grease contamination), so just drain and refill with fresh gear oil. The transfer however calls for 75W-90. Many mudders use Mobil 1 synthetic gear oil, 75W-90 for all the gear boxes.
Ok Thanks!! Going to add the Rislone this week and let it run while I go camping this weekend. Plan adding the 5 minute flush and doing a oil change when I get back. Also plan on doing the front diff engine flush trick next week too. Then I tacke the tranny and transfer case. I had a new radiator installed not long ago after mine cracked. That shoul dcover my with fluids. Thanks again. Ill let you know how the diff and engine de-slug go.
