Help with Connectors ID
"the whale's vagina", CA
Hi All,
I am working on a 1997 collectors edition with a wits end turbo going into it. A bunch of the wiring harness connectors have fallen apart. One I don't have the connector to pull the # from just a leftover wire. It is on the same end of wire harness as the green connector with 10737 11062 stamped on it.
Can anyone look at their harness if they have it available and provide this specific plug part #? hoping someone has a harness removed and can take a quick look at it. My finger is pointed to the connector # I need.
Thank You!
Noah
I can't do what you've asked. However, you may find it in a thread titled something like
1995-1997 obdII main engine wire harness connector info.
Thread started by Beno.
thank you yes I looked that one over but I have no plug to compare with
What do have in the pic?
Knock sensor, coolant temp sender, temperature vacum valve...
I cant recall what the 4 connectors are right there on the ds. The area is below the intake and near the oil filter. I've seen pics where folks have written in what all those connectors are for but finding them on my phone with slow wifi sucks.
Hard to read some of these but I believe it is as follows:
A - 11016 - N19 (could be 11018 - NI9?)
B - 11428
C - 10737-11062
D - 11166
Satchel, thank you! I think D is what I need. Mine has the same color wire and is only a one wire connector, correct? There are 5 connectors on that branch and one of them is rounded and has no visible number on it. So it has to be #D
Noah
Noah
You are correct, I missed that other one as it was tied away. It looks like the below, and I agree that the one you need should be D, or 11166 from what I can see of it. That one is written crazy small...
Plug D is correct. 11166 is the #.
Main Engine wire harness.
DS under the plenum and by the oil filter. What ya got there... knock sensor, temp sender, temp vacum valve and maybe the crank position sensor. Just guessing from poorly treated memory.
