Help with Climate Panel Control
I have a 1997 Landcruiser Collector's Edition. I'm getting ready to sell it but a problem popped up over the weekend and I'm wondering if anyone has any idea what may be wrong. I'd like to fix if if I can. If I can't then I'll just let a buyer know.
When I start the vehicle the Climate Panel Control lights all blink in concert with a clicking sound from under the dash (above the pedals). No air comes out of the vents and its like the heather or AC isn't on. The top row of buttons (like the defroster) light up when clicked and I hear a click when I depress the button. However the AC and Auto lights never come on when pressed and there is no click for those buttons. Finally, the clicking sound under the dash is pretty loud but when I turn on the headlights it gets softer and then eventually goes away.
I've checked the fuses to the left of the steering column and someone recommended making sure there was plenty of coolant, so I added that to the max line (not sure on that one). Those were both hail mary ideas and didn't fix it.
Any ideas on what it may be and how complicated/expensive it will be to fix?
Thanks!
Shot in the dark, but have you checked the AC belt? Or is the 97 a serp. Also, is the dash a factor dash, or is it a kit with an aftermarket setereo?
Thanks for the suggestion on the belts. I checked and they look fine. Dang, wish that would have been it.
Maybe it's water in the AC amplifier.
Did you give the interior a good washing before you put it up for sale?
Found this: https://forum.ih8mud.com/threads/be...your-electrical-components.42063/#post-461390
I haven't cleaned it inside yet but it was driving rain when this happened over the weekend. I didn't notice any water ont he floor board but I suppose it could have some in from the outside. Looks like that part is EXPENSIVE. No offense but I hope someone comes up with a "better" or should I say, a less expensive idea. :)
Thanks!
Try disconnecting the battery for an hour or two and see if it will reset itself.
Mine had the same issue, this is only for the cruisers with auto a/c feature in the climate control panel. I think its only for the 40th anniv and the LX450. So if you have the auto button on your ac display then you have the same issue I did. When you push any buttons and nothing happens except lights. where you hear the clicking there is a white box, near your right knee under the dash. this is the AC amplifier, its quite expensive new, IRC it was around $600 new. I found mine from a junk yard. If your gonna look for one, make sure it comes from a LX450 or a 40th anniversary. I paid around $150 for the used part. Once I plugged in the new one the AC and everything else functioned as normal.
Hope this helps!
Hope this helps!
Florida-
Thanks for the junkyard suggestion. How tough was it to remove the AC amplifier. I see it under the dash and it looks like there is a bracket on the back with some screws. But I wasn't sure if I needed to remove the dash or whether there was any trick to getting it out?
Thanks!
IRC its only 1 or 2 10mm bolts. Not hard at all. Real simple to remove
hi everyone...just wanted to say thanks for the help and advice. I was able to take the AC amplifier off and clean it. When it was removed the clicking didn't happen anymore, so I think it was the problem. However, cleaning it, didn't work for me. Looks like the answer is a new/used amplifier.
Could be the control panel too
Thanks again everyone. Just wanted to thank everyone again. A nice guy ended up buying the nice cruiser. I told him about the issue and he is going to continue investigating it. I also found out my check engine light was really just low antifreeze (not out but just low...). If I hear from the new buyer on the root issue, I'll report here in case someone else has the same trouble.
This just happened to me today I think. Same exact symptoms...
Is it that computer thingie for the auto-A/C that is usually the problem?
Part #88650-60212
