I finally got around to finishing my pigs engine assembly - got the carb back from Mark and the last little pieces from cdan ... but she didn't fire
I don't think she's getting spark so I'll have to search up there.
I do have a couple of questions about the F engine since I never actually saw it together ... just lots of parts in boxes. Where does the distributor pull vacuum from? I hooked the carb diaphragm up to the port at its base, the PCV to the tube on the carb spacer and the brake booster to the port on the intake manifold ... don't see anywhere else to get vacuum (there is another port coming off the spacer ... but the PO has crimped it off). Secondly I have three wires that are crimped into one on my alternator plug (three wires into the perpendicular blade) - this doesn't seem to be right and was smoking! The plug only has three blades - could someone have put the wrong alternator on it?
Sorry for the long winded post - any help would be appreciated!
Tucker
I don't think she's getting spark so I'll have to search up there. I do have a couple of questions about the F engine since I never actually saw it together ... just lots of parts in boxes. Where does the distributor pull vacuum from? I hooked the carb diaphragm up to the port at its base, the PCV to the tube on the carb spacer and the brake booster to the port on the intake manifold ... don't see anywhere else to get vacuum (there is another port coming off the spacer ... but the PO has crimped it off). Secondly I have three wires that are crimped into one on my alternator plug (three wires into the perpendicular blade) - this doesn't seem to be right and was smoking! The plug only has three blades - could someone have put the wrong alternator on it?
Tucker
