HELP What is causing this leak???
Utah
I was told that I needed new axle seals but I dont know it thats the problem. Please look at the picture and let me know if Im in the right direction. I have already started on the passanger side and I dont think its the axle seals unless Im not in far enough. THanks
Welcome.
Dig deeper...
That is from the inner axle seal leaking...
Keep removing pieces and you will see the seal....after you remove the axle shaft.
Good luck!
-Steve
You will find the seal, covered in oil and grease....it is right in the middle of the knuckle ball on the end of the axle housing.....pay no mind to the prydriver in the pic.
Thanks for the help... Yeah I found it in there and got it pulled out, now Im having a hard time finding new ones. Is it called a differential seal?? The inner axle seal apperently isnt what Im looking for. Anyone have a part number or know where I can find some?
90311-33085 Toyota part number...
Dan is the man
Good luck!
-Steve
Axle seal gremlins reeked havoc on your seal:eek: It happens to the best of us:grinpimp:
Well I dug into the drivers side where the leak was alot worse and this is what I found. Looks like someone very skillful worked on it and tried to fix the leak. Do you think this is fixable??? I dont know what to do now!!
You're gonna need a dremel to clean up the burrs around the seal hole once you pry whats left of the seal out, but you should still be able to install a new seal and run it without issue.
If it's your first time in a front axle, I'd recommend buying a couple of extra seals, just in case you damage one while you're getting the hang of it. They're cheap enough.
Good luck.
Mark A.
HEY,FJ401977, be sure to wear safety glasses when using a dremel! November is Eye safety awareness month:eek: I don't wanta read here about you gettn your eye put-out by flying axle debris:frown: machine away! Fuzz
