97 lx450
Just completed knuckle rebuild and tre replacement.
Went to get inspection and found that I have no brake lights.
Bulbs test.
.03v on all three connections with brake pedal depressed
11v across the fuse terminal
10a Fuse for the stop lights tests good
Grounds look good in the rear underneath the truck and center. I think the correct wire is the wight/black. I have the factory wiring fsm.
Truck is equipped with a factory tow harness.
Blinkers and tail lights work.
I'm not sure what to check next. Please help
JB
Bulbs test.
JB
