Help, trollhole dizzy
Georgiafj40 - I have read the write ups on trollholes page. They were very helpful! The one on page three of the dizzy thread walks you through everything.
Pin head - I have attempted the combination of the old coil and new dizzy, with the power wire for the dizzy going to the same side of the resistor as the switched key power.
I must just be low on voltage. I need 12 while cranking right? And now I have about 10.
Any suggestions on places I should start looking for where it's dropping at?
Sent from my iPhone
It is not unusual for the battery voltage to drop to 10V during engine cranking. The question is whether the ignitor will work at that voltage. You could try jumping the + side of the ignitor to the battery or even another battery not used for cranking to see if that is the problem.
Jumping it sounds like a great idea. I wasn't sure if that would work or not because I am not actually sure why this dizzy uses power and the other only needed the ground. (Never owned a thing with a dizzy before) lol
I will try jumping it next time I am with the 40.
Is there any way to bench test the new dizzy. It should open and close the ground side when I spin the rotor right?
Sent from my iPhone
The ignitor inside is electronic and it needs a power source. The old school points type only need the wire to the - side of the coil.
Sure you can bench test it. Just wire up the coil and spin it and it will make a bunch of sparks. Make sure that the distributor body is grounded or you may get zapped.
Well getting zapped by the coil probably should be avoided, if I want to keep working in this project. Haha.
Thanks for all the help, glad to hear that I can jump to the battery and test. Also I can test the dizzy.
I'll let you all know how this turns out.
Sent from my iPhone
Just to update and wrap up this thread. I called marshal aka Trollhole. He sent me a new module and it works great.
I wired the red wire to the 12v coming into the coil and the black wire to the negative side of the coil.
I extended the black wire and shortened the red.
Anyways it works great now.
Thanks for the help everyone.
Reed
