Help, trollhole dizzy
I need some help.
I have the dizzy installed.
Red wire with the white sheath going to the positive side of the coil.
Black wire going to the negative.
New coil, non blast resisted.
What am I missing?
Help!
Sent from my iPhone
what year fj40?
What do you mean non resisted coil? internal ballast?
Have you verified the coil is getting 12+ volts?
Does your carb have a vacuum advance port at the base?
OK but do you get power to the coil when cranking? should see 12+ volts, if you aren't getting power to the coil then you have to work back from there, could be ignition switch. But you have to check to see if you have power at that coil.
spark tester wont work, need multi meter or test light.
a healthy battery should be higher than that, but if it cranks. You can take the lead from the coil and hold the end that should go in the dizzy close to a ground while cranking, should see a spark here. be warned even touching this wire you may get shocked.
If you get a spark then your dizzy may not be getting power.
Mine did the same thing when I bought it. The PO said it was supposed to start like that. I would have to get the engine rolling in the starting position of the key switch and then let off quickly and then it would fire in the run position of the switch. Very annoying. The PO had left off a wire or wired it wrong. You need a good wiring diagram. Your missing a wire or someone has wired it wrong. I'll try and look through my wiring diagrams for u if u don't get it.
First off thanks for the help. I was unable to get any spark, so I took out the trollhole dizzy and out back in my stock one. Set the timing and it ran like a top.
So to summarize what I did above. Hopefully someone can give me some more guidance.
First I have a march of 72 fj40. It has a what looks to be a stock dizzy, and a stock coil. The coil is ballasted resisted.
I installed the new dizzy, replaced the the coil with a non ballasted resister. I hooked the red wire from the dizzy to the positive side of the coil, along with the switch ignition wire. I attached the black wire to the negative side of the coil. This resulted in no spark, I was using an inline tester that I had tested on a running vehicle.
I then tested my battery, 12.5 volts. I then tested the power going into the coil, 12.5. Drops to 10.5 while cranking.
I then put the spark tester in line between the coil and the dizzy. There was a spark produced when the key was first turned to the on position, but nothing after.
Any help would be great?
Is there anyways to bench test a dizzy?
Sent from my iPhone
can you post a pic. of the sticker on your coil? looks like an accel coil. As far as I know there are only two types internally resisted or external. What is the primary and secondary resistance? If I remember correctly the TH electronics have to see 12v.
Can you post a pic of what wires you have on your coil + and -?
Good morning,
It is an accel coil. And I have the box in my car, I'll grab the pictures you requested at lunch.
I am not sure what the primary and secondary resistance is. Is this on the box or something I will need to test for?
Sent from my iPhone
Ok. So as you can see by the last picture I had the red wire from the dizzy to the positive side of the coil and the black to the negative. Also when it was in the truck I had the switched power to the positive.
Is that the right coil, or is only good for points?
Sent from my iPhone
does the stock coil work? use that with the trollhole dizzy.
I tried hooking up the stock coil to the trollhole and it didn't work. No spark.
My stock coil had a ballasted resistor so it only works on like 9volts. I need 12 for the trollhole, that's why I bought the new coil.
Sent from my iPhone
Im sure it is a good coil. But it only has 1.4ohm primary resistance so you would have to use a ballast resistor or a different coil. I used a pertronix 40511 with 3ohm.
Sounds like you had it wired correct. And you said with the ignition on you had atleast 12volts between the + on coil and ground on battery? I would get the higher resistance coil wire it like you had it. You have to make sure there is at least 12 there. elec. ignition has to have it to work. If still nothing call marshall, he backs his stuff pretty well. If you do not have the 12 volts you need to track that down first.
You could use your stock coil and hook the red wire before the resistor I think. Have you went to vendor forum under TH and searched the dissy thread? There are some nice right ups on this there.
