'92 FJ80 (3FE and drum brakes in the rear - similar to a FJ62)... This problem has been evident for 6 months or so, but seems to have gotten noticeably worse just today.
6 months or so ago, I started the truck, released the parking brake, put it in reverse to back out of the driveway and it felt like the parking brake was stuck. I could feel that the engine was working against something to make the truck move - not rolling freely. So I engaged and disengaged the parking brake a couple of times, backed out of the driveway, then went on down the road with no more problem. Also, the problem mostly seems to be evident when the truck has been sitting for a while.
This same kind of thing has happened about 50% of the times I've cranked it up in the morning since then, but I sort of learned to live with it since it always loosened up pretty quick and I just did a brake job a year or so ago (less than 10k miles). Also I only drive this truck once or twice per week.
In that 6 months or so, I have noticed that this "brake sticking" sometimes happens when the parking brake had not been engaged at all. In those cases, I'd drive forward a couple of feet, reverse a couple of feet, then forward a second time would always seem to loosen things up so the truck would roll freely. It has NEVER happened except on start-up, meaning that it's not like I stop at a stop sign and have the brake get stuck. It only happens when I first start up the truck.
My first question is: How can I be sure this is a brake problem and not something going on with the transmission or one of the diffs?
My second question is: Has anybody else had any "symptoms" like this?
edit to add: There IS rolling resistance. Not an issue with power not going to the wheels, but something holding the wheels tight... which is why my brain defaults to a brake problem.
Thanks
Thanks
