Help - Steering Wheel Crooked
california
When my tires are aligned straight - the steering wheel is crooked ? Is the fix taking the steering wheel off and putting it on straight ? 🤔
That would mess up your turn signal release points and the center point of the steering box. I assume you got an alignment and have the toe in set correctly? If so, you should then loosen the rod going from the center arm to the tie rod. Twist that out or in until your wheel is centered.
I guess I should ask what rods you played with? If you know your front wheels are aligned correctly, your center arm is in the middle position, then you can adjust the rods accordingly. If not, get an alignment and they will make sure all is correct.
If your wheel is off I would check the condition of the tie rods and steering components. Check toe in of tires.
i was beaten!
Thanks guys - I have not had an alignment done, maybe a dumb question... but is a specialty job or can any alignment shop handle the job ?
You can probably do the alignment on a flat spot on your driveway or garage.
You will want to prepare all the bolts with penatrent for a day or 2 before you tackle the job. You can use 2 straight edges parallel with the ground on the center of front wheels and measure the front and back of the tires. you want about 1/8 toe in. Do you have photos of your front tie rod ends and steering components? If your going to the trouble of alignment they will need to be in good shape and no play.
Hey Curt - I don’t think I am at the skill level to do it myself ... I think I should look for a shop in LA that has done alignments on FJ40
To answer your question, not necessarily. it’s unlikely that a previous owner pulled off the steering wheel and put it back improperly clocked. It’s more likely that the truck hit something hard. Check for a bent tie rod/relay rod, etc. Dont begin at the tires and work your way back. Center the steering wheel, then go through each component and put back to factory settings, working your way up to the tires. You’ll find the problem. There aren’t many jobs easier than a front wheel alignment on a Land Cruiser. There’s no camber or caster adjustments, only toe-in, which is 5 degrees, or about 1/8” . A Toyota factory service manual will guide you. If I can do it, you can. 👍😊
Sheer curiosity. I want to know t
Can't you just remove the steering column bolts under the dash, loosen the rag joint and turn the wheel to center. Put everything back.
he story of my Land Cruiser. It was my first car, and I never intend to sell it. I'm 19 now, and I bought it about 4 years ago after it had already lived a season 45 years on the road.
This is the easiest, one bolt under the rag join, loosen, lift off splines, rotate rag joint, steering column, then slide back over splines when wheel is straight, tighten nut.
It's actually easier to center the wheel properly, by adjusting either the relay rod or drag link.
Local tire shop here in TN sells a lifetime front end alignment, pretty easy to wheel and run by the shop few weeks later for the alignment after every trip.
Nik
I have to repeat that it is not really safe to just center the wheel if other components in the system are either worn, bent, or out of whack.
I'd first download the PDF version of the body and chassis manual for your year truck here. Read the section on doing the alignment. If it seems like something you didn't want to tackle, take it to reputable mechanic or alignment shop and give them the pages from the pdf. I usually ask if I can watch the work if it's something I'm not comfortable doing so that I can learn. Many shops have been cool with that.
I never take shortcuts on safety items like brakes and steering... Cut corners elsewhere if you're trying to save a buck.
Where in LA are you? There are a few good places that work on Toyota rigs depending on where you are.
Which bolt ?
The rag joint is centered in the pic., the bolt is facing shiny gold bolt facing you. You must pull the bolt all the way out in order to lift off splines, rotate then slide back onto splines. It should take about less than a minute to do including re-tightening. This pic is provided by @SSCR here on the forum. Don't forget to anti-seize (every bolt/nut you remove). This method may not perfectly align the wheel. For a certainly perfect straight steering wheel, you may need to adjust the relay/drag link rods.
