HELP: seat bracket issue
Groveland MA
Website
landtankproducts.com
I ran into a problem with me seat brackets and am looking for input from those who have installed them.
A few years ago I put 2 sets in for a guy with an LX450. All went well except for the outside rail of the drivers seat. On that rail the holes for the front foot would not line up, they were about 2mm off.
I measured everything and found that that rail had been made differently than the other three and assumed it was a single mistake at the factory.
Well, that truckis back in for other work and I needed to repair a motor assembly on it so I bought a used seat and decided to replace that bad rail as well.
To my surprise the rail from the new seat was off by the same amount and upon further checking both rails on that used seat were off.
It seems that Toyota had at least two jigs for positioning items on those rails and they differ by 2mm.
What I'm looking for is feed back from people who have installed my brackets and either had no problems or if they did.
It looks like I need to alter the design of the bracket to allow for this variance in Toyota's production.
Thanks for your help :cheers:
Don't have your brackets but if you want me to measure anything on my 450, let me know.
Thanks John but it's not just a Lexus thing as the used seat was out of a 1993 LC. I'll make the design change regardless. I just don't like putting products out there that don't perform or install properly. There is enough of that crap out there and I don't need to add to the pile, so to speak.
I have a 96 LX450. I have brackets on both front seats. All holes lined up.
Rick there are two different part numbers for the lower track assemblies.
The 93-94 trucks used different numbers that superceed to the later 95-up numbers. The later numbers are also used on all LX450s.
In theory they should all interchange. I believe the change related to how the back moves and had nothing to do with the floor mounting.
Thanks Dan but the issue is not where it mounts. There is a block welded to the rail where the following nut bolts to. This is how the seat is moved back and fourth.
The distance from that mount to the front foot is different on these rails.
For those who have used my brackets, the bracket gets bolted to this block wit M8 cap screws and the front foot gets bolted through the rail and my bracket with some M6x30 screws. It was a problem getting those 4 screws lined up.
I see what you mean. I did not do a good job of conveying that as far as MR T is concerned all the frame assemblies should interchange without fitment issues (as they relate to the floor of the vehicle). There must have been a difference in part of the manufacturing process that does not affect the way the base fits in a stock-configured truck but does affect how your brackets mount to the base of the seat.
when I discovered the difference initially the owner remembered that the seat had jumped it's track when he moved it all the way back during the test drive. This was the chair with one of each of the rails and the assembly would have been cocked during it's travel.
Rick,
As you know from my note that I have a 96 LX450 and recently installed them with no troubles whatsoever.
Thanks again.
Good luck w/ the glitch. Still wayyyyy worth it.
Scott
