Help - Rear heater hose replacement
Detroit
My 1996 LC started leaking fluid a few weeks ago. Traced it to rusted pipes underneath.
I have bought replacement pipes and removed the heat shield. The heater/pipe parts come in 2 sections: part 1 from the rear heater core to just beyond the cats, and Part 2 from the firewall down.
I have removed part 1.
I have separated part 2 from the underbody and also from both the T pipes at the firewall.
Does anyone know how pipe 2 is removed (pull from top or pull from bottom?). This thing is twisted into a ridiculous shape and I have no idea how to take it out with the engine in place.
Anyone with experience on doing this entire replacement job without bypassing the rear heater core?
Urgent help needed to fix this before monday.
I have bypassed my rear heater system and have not yet pulled out any of the pipes. I went to this website:
ExpeditionLCMajorcoolingoverhaul
Brian is a MUD member and his website is yet another wonderful resource to us 80 owners. Anyway, back to the task at hand. There is a drawing, if you scroll down to the "Heater Hose Description" section, and print it as a reference. This is much better than anything I could find in the FSM (Factory Service Manual) about front and rear heater hoses. It looks like, from this drawing, that the section of pipes you refer to as "part 2", should be pulled out from the top.
I would also recommend, that you take this opportunity (coolant drained from system) to replace other heater and radiator hoses that are original, including the infamous PHH. Search on MUD or use Brian"s website for some excellent help on this. HTH:wrench:
Thanks for the information. Unfortunately, even though the information was very detailed, no specific step-by-step guide to removing the rear hose fitting was added. I have done the PHH already, some time in July 2007 when it was nice and warm. Now it is too damned cold up here in the D.
I guess I will have to wing it from here.
Here's a thread where they're talking about problems just like yours:
https://forum.ih8mud.com/80-series-te...ter-pipes.html
I don't know if you've ever used search, but this was fairly easy to find. I used rear heater as the keyword, search titles only, in the 80 Series tech forum.
I changed mine out while the tranny was off the truck. Those pipes are in a real bad spot and require you to remove two bolts that are located just behind the engine on the fire wall. If you drop the rear drive shaft and lower the tranny by unbolting the cross member you might be able to get up in there.
Good luck
I am throwing in the towel. I am going to do the bypass at the firewall since I don't have enough time or warmth to drop transmissions right now. I will have to hold on to those parts since the Toyota Stealer will not refund my $320. Maybe one day if the tranny is ever due for servicing or rebuild, I will use that opportunity to do a proper fix.
Thanks for all the help.
pistolbob
how did you bypass the rear heater? just add a single line @ the firewall? or did you change the T at the firewall?
I'm working on it now...
pistolbob
Sandcruiser, when I bypassed mine, it was pretty easy. I just removed the 'T's and like pistlebob said, just left the pipes in place. The 'T' above the PHH has an odd shape to it - no big deal, but other than that, just cut longer lengths of hose to run from your front heater connections on the firewall to the existing connections left when you removed the 'T's. It's a simpler system that way - fewer problem areas. Oh, and I took a bead of silicone sealant and blocked off the top of those unused rear heater pipes, just to keep out debri (sometime down the road you may change your mind). I plan to drain the coolant out of the rear heater system, but there's no rush since it's not being used. HTH
(Edit) You should also remove the short length of hose left at each end of heater system when you remove the 'T' so the longer hose length that I mentioned above can be attached with hose clamps.
I'll post photos later, but here is what I did.
I pulled off all the rear heater hoses/lines. Getting the firewall hard lines out was a challenge, but I eventually just cut/bent/broke them enough to pull them out.
I live in the tropics for goodness sake- I can' t envision putting the rear heater back in! If I ever feel the need for more heat, I'll install seat heaters in the front and rear.
Anyway: pulled those lines off and placed them aside, leaving two pipes coming out of the firewall for my primary heater core, and a pipe on the pass-side of the motor near the turbo, and the heater valve.
I ran about 50cm (18") of 3/4 gates heater hose from the motor connection to the pipe on the pass-side firewall. 5/8" would have fit tighter, I think, but with hose clamps the 3/4" isn't leaking (yet?).
Then I ran a long chunk of 3/4" hose from the other firewall nipple to the valve. That kinked. So I tried a shorter chunk and it works better, but still is partly kinked. Again used worm-drive hose clamps (plain old stainless). I had to tighten those clamps pretty tight to avoid leaks as the 3/4" hose is pretty loose on those pipes. I plan to replace with 5/8" when I find some 5/8" hose (local parts store is out of stock on that).
I'll post a photo or two later. On the surface, the job is pretty easy. Just buy 3 feet or so of hose, depending on where the water returns to the motor on a gasser, and four clamps.
Getting everything to disconnect isn't that easy- the bolts on the firewall to remove the hard lines are very tough to access. I found that the best way was to use a very long extension (14" or so) and a wobble on a socket. That gave me enough room to turn the ratchet handle. I did leave some skin on various motor surfaces in the process.
Once everything is disconnected, and assuming you have the hose handy, the rest is pretty simple. Including a thorough flush of the rad and the heater core, the job only took about an hour to put everything back together.
I used a 24" extention on a cordles drill. I thought ahead and used mechanics gloves from Pep Boys so no skin lost. I did not replace the "T" I just used a piece of hose in both places. I agree that the hose closer to the center of the vehicle realy sucks to get to. I actualy used an electric carving knife that my inlaws gave us for christmas two years ago to cut the old hose in place because I couldn't reach it with anything else. Sorry I didn't take any pics.
Carving knife. Genius.
I'm happy to report that after driving for the day, no leaks so far!
When I pulled into my driveway, my heart sank as I saw water POURING off of the driver's fenderwell... then I realized it was just coming from the washer bottle because it has a hole in the back corner and I overfilled it. Whew!
